![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
The information on the Sussex Autos website certainly indicates that there was a design change from 2011MY and that the earlier input shaft isn’t interchangeable and, worse still, is no longer available.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Hi Phil, how far do you think I should be able to rotate the front output flange before the rear one would move?
Hmmm. I’m afraid I don’t have a transfer box here to test it on right now, but I would say that the free play isn’t just the chain slack because the backlash in the bevel gears of the centre differential also has to be taken up before the drive between the two flanges becomes solid. Approximately how many degrees of rotation are you observing?
I'll have a look when I'm a bit more able Phil thanks. |
Sorry for the delay Phil.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
I think mine could have a similar number of degrees of difference between the front and rear output.
