![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
dantudor Member Since: 13 Sep 2014 Location: bucharest Posts: 1 ![]() ![]() ![]() |
Hy there. Can you guys give me a hint about the dd295 drive chain. Mine is lose and needs to be replaced. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Oh no mark, I hope you don't have the same issue as me. I have been under mine dozens of times now and it is a complete mystery. It is only when it moves and it is not getting any worse (which oil leaks normally do) let me know how you get on. I'm planning to take the box out soon and fit RRPhils casings. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Yep, not leaking when stationary. Had stopped leaking! It was fixed before I did the normandy run with the van on the back and i checked it before we went to the south, no leaks were visible.
I hope you havent got the same issue as me??? |
Box is out and I can't see any evidence of porosity?? In fact I can't see anywhere where it could be leaking from? This is a mystery? |
I know. Its a nightmare.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi chaps, just wanted to suggest something that you may have overlooked......... Have you looked at the breather? There must be one some where on the top of the box, and if its blocked, the box will p#ss oil from every seal when its hot. Only a thought, but could be worth considering, if you haven't already.
Good shout there, it is a possibility but have checked round the breather as best i can and its fine, pretty sure it terminates in the engine bay also. There is nothing that can't be fixed with a hammer😜😜
Got under mine today with my E6 socket.
Think I have found it!!!
Do tell sir!....... There is nothing that can't be fixed with a hammer😜😜
Well. .. it had definitely been welded..... I will post pictures..... and some sort of paste / filler was on the inside of the casings, so there was a leak / crack / porosity at some point, but it was NOT leaking from there any longer, but I had obtained RRPhil's spare casings so I intended to swap them and see what happens.
Flange and core plug type cap that had been disturbed?
looks like the new casings should fix that well enough. You will have to transfer all the other things over which have a gasket or oring, so a good chance to get the seals on those replaced too! There is nothing that can't be fixed with a hammer😜😜
