Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown
Page 6 of 9 <123456789>
Ah in that case I would have a look at the chain. There are a few cases of these stretching though it's not that common. New chains are available but from memory a PitA to get hold of, I think there is a supplier in the states.
Do you have your original box? As you can see they come apart quite easily, and are just silicone sealed together. If you can get the two on the bench you may be able to make a good one out of the pair either by putting the bearings out of the replacement into the old one or the chain/broken bit into the new replacement. I would haazzard a guess if you opened them up you will see the problem. There is nothing that can't be fixed with a hammer😜😜
Post #409987 20th Oct 2016 5:54pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Great write up, and looks like a "cheap" fix if the pump hasn't been damaged Wink
I'm sure your work will be appreciated Thumbs Up
I love fault finding on things and fixing stuff in general, but I'm currently trying to find a dead short on my ERF 38t EC11 artic, caused by a battery failure/jump start, not getting great pleasure at the moment Censored Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #410002 20th Oct 2016 6:38pm
PHG
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Just an update for all those people who find this thread whilst researching their own transfer box issue. Mines a 2008 FFRR TDV8.
One of my output shaft bearings failed (to rear prop), sounded like a wheel bearing in the early stages. I fitted a second hand transfer case which sounded wrong from day one, it banged and clanged when turning corners. I was told it might need calibrating on autodata or similar but it turns out the second hand box was u/s. A new bearing was sourced from Emmett Enterprises in Stockport, £11.50 plus vat and my mechanic friend split the box, changed the bearing then refitted. All the parts need to be dragged out of the bigger side of case and stacked in the smaller side of the case so that the two arms with roller bearings on can be pulled apart and seated properly. As mentioned before in this thread you must use the special landrover only oil. It says "special transfer case oil" on the front of the bottle, £25.00 plus vat per litre. Also make sure you obtain a new output shaft seal LRO86042 or IZB500050, it has a dust lip on it, so landrover only £12.50 plus vat. A worry on the refit was that the input, and both output shafts appeared to be diff locked together. On start up the hi low lights flashed, transmission failure on the display and awful noises came from the box. Drove forward 1 meter, then back then turned the ignition off and on and everything was fine. Going to try and get a refund on the second hand case. 2015 SDV8 AB
2008 TDV8 Vogue gone
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #411091 28th Oct 2016 10:37am
RRPhil
JP Automatic Transmissions near Bristol advertise that they stock parts for the DD295 transfer box
Phil
Post #411133 28th Oct 2016 3:51pm
Bodsy
Just going through the refurb of a spare transfer box I have. No info on removing the bearings on this thread, are they all fit to 'stop' or need to be a set depth?
Thanks all.
Post #426984 9th Feb 2017 12:19am
miggit
Rolling Eyes Special transfer box oil... isn't that a posh name for fully synthetic hypoid oil? unless there's an LSD in the later boxes, then it's LSD oil that's needed Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #427001 9th Feb 2017 10:02am
PHG
Hi Bodsy the bearings seat in their stops nicely, no need to worry about pushing them too far. One thing that caught me out (amongst others) was the cir clips on the input and output shafts press in, into the shaft not out. 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #427007 9th Feb 2017 10:22am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
really good write up, looks like a pretty straight forward rebuild.
Post #427015 9th Feb 2017 10:42am
PHG
Hi, the write up is all down to RRPhil, I just used it to help me with my noisy transfer case, still had a though time even using RRPhil's write up 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #427017 9th Feb 2017 10:47am
Bodsy
Useful info, thanks. I had been looking at them and figuring out that they can only really go in as just not enough space to pick it out. Thumbs Up
Bearing kit arrives tomorrow, so will see how it goes! Thumbs Up
Post #427087 9th Feb 2017 8:07pm
Bodsy
DD295K bearing kit arrived from Advanced Factors this morning, so off out to have a play...
Post #427151 10th Feb 2017 12:02pm
Bodsy
Most of the bearings replaced, decided not Tibet change the one at the eng of the selector shaft as I'm pretty sure that'll be relatively low impact low useage.
Just the one blind bearing to do tomorrow. Need to see if i can get hold of a slide hammer blind bearing puller set tomorrow.
Or I might leave that one. Lol.
Ok, so the belvoir washers, I've forgotten to take a pick of where they sit. I thought they were at the bottom of all the gubbins, but then I think the spacer was as well.....
Did they go together at the bottOk or should the spring loaded washers go at the other end....?
Errr help.....
Post #427209 10th Feb 2017 5:51pm
Bodsy
Autocorrect! Belville not belvoir.
http://s260.photobucket.com/user/GearShift...1.jpg.html
Post #427210 10th Feb 2017 5:54pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
RRPhil wrote:
Although I’d expected this 6210 C3 bearing to be manufactured by one of the ‘high end’ suppliers such as SKF, INA/FAG, NTN, etc. it’s actually manufactured by a company I’ve never heard of – ZKL of Slovakia.
Phil
INA stuff for the Land Rover 300tdi timing pulleys are made in Slovakia.
Post #427255 11th Feb 2017 1:05am
RRPhil
Looking at the diagram in the manual, the two springs appear to be stacked in series between the circlip and the bearing.
Phil
Post #427300 11th Feb 2017 2:59pm
