![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
My current theory is that the Magna engineers will have specified ‘proper’ bearings for their transfer box but then their procurement people found some nice cheap ones from Slovakia, and these are not up to the task. This theory is based on a sample of one and I may well be proved wrong on this! I still find it interesting that Magna have chosen to axially preload this input bearing (with two disc springs/Belleville washers) - makes you wonder if they saw issues with this bearing during development?
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Pm sent Phil |
I’ve never tried removing one of these transfer boxes myself. From the workshop manual it appears pretty straightforward but it looks as though the top four bolts are a pain to access and Land Rover recommend a special tool (wrench adaptor) :
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Makes great reading
I’ve finally got around to dismantling the combined centre differential & low range reduction epicyclic assembly.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
An excellent write up Phil.
gruodiz Member Since: 09 Dec 2011 Location: LT Posts: 10 ![]() |
Very interesting, informative write up Phil. I really like to read this one and ZF 6HP26 write ups.
RRDEL Member Since: 11 Mar 2014 Location: USA Posts: 1 ![]() ![]() |
I have the same transfer case with a stretched chain (like the old ones).
I believe that Cobra Transmission (Miami) stock the chains
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Hi phil,
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I'm on my third seal too - mine turned out to be a crack in the casing.
Hi Phil.
bump |
Yes I have, though I’m struggling to find the information again. It may have been from a Discovery or RR Sport bulletin board because they use the same transfer box. I definitely recall seeing photos of cracked/porous transfer box casings and they’d been like that since new. I’ll see if I can find it again.
