![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
I’ve just bought a poorly DD295 transfer box off eBay for £50 as I thought it might be fun to strip one down to see what’s what. The seller’s description was that it “did drive but was noisy” and I can tell just from spinning the input shaft by hand that there’s something very wrong inside – it feels extremely rough.
Great stuff Phil |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Still hitting the refresh button |
Phil on behalf of the forum members here,
Unfortunately it’s not an option to swap the two transfer boxes as they were never designed to mate up to the same transmission. I would imagine that their installation sizes are different too. Also, their control systems will be quite different as the passive Torsen centre diff. in the NV225 was replaced with active clutch control in the DD295.
Thanks Phil, I'm off to bed right now |
The two halves of the casing separate easily with almost all of the components staying with the rear casing
Really interesting Phil, I take it the bearing is the only problem you've found so far? |
Yes, just that input bearing – and I strongly suspect that’s all I’m going to find wrong with it. None of the box’s internal parts are available from Land Rover so I’ll get the bearing out, check its size and get a price from a local bearing factor (just out of interest).
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Is it just a lack of fluid that has caused the bearing to fail? |
Thanks Phil, top post |
The failed input bearing turns out to be a plain, single row, deep groove ball bearing of size 50 x 90 x 20.
Any idea of the bearing failure Phil?
