![]() | Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 ![]() ![]() |
OK, clarified the washers, they need to go against each other as seen here.
Transfer box all back together again, ready for fitting on Wednesday. Thanks for the info on here, it's been really useful. |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Hi Phil
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I’m not sure which drawing you are referring to? Unfortunately, I don’t have a DD295 in my workshop at the moment to be able to measure the seal depth. Maybe someone else can help? The 308-598 tool has a machined face which abuts up against the casing when the seal is installed to the correct depth, so I guess you are asking the question to avoid having to source the special tool?
Many thanks Phil. Whilst searching around for a measurement of the oil seal depth, I came across a rough sketch of the LR tool but it was so pixellated that the measurements were not clear enough. I'm sure it was in one of your threads on the DD295. I made the great mistake of not remembering where the seal was when I took it out and I pushed the new seal in just 2mm too far. The result was the oil seeped out - which I only discovered on the test drive. Anyway, to cut a long story short, I could see the two limiting points beyond which the seal could not go, otherwise it would leak. So I placed it halfway between the two - which was at a depth of 22mm. I turned a piece of aluminium bar to ensure that the seal went in square.
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
I've got a problem with my Transfer box (my thread here), no worrying noises or range selection issues. It's just the centre diff seems 'stuck on' so turning or parking sees the tyres scrubbing big time. I found these codes in the TCCM:
Still trying to get SDD to work |
So, is the shift motor definitely functioning okay and turning the splined motor shaft? i.e. are you able to select low range and then get back into high again? The shift motor controls the range change with the solenoid off. With the solenoid on, the shift motor controls the clutch actuation.
Hi Phil and thanks for the reply.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
The solenoid is pretty accessible and bolted directly to the outside of the casing.
I've noticed this morning that when the car was cold, all seemed to work as it should. It was only after she warmed up a bit that the tyres started scrubbing again.. |
I’m still not sure, though, how the solenoid – even if faulty – could cause the clutch to lock in the ‘on’ position.
'Clutching' at straws here, but perhaps a fluid change on the transfer box..? |
So it's been a few days. I managed to get under and checked the connections to the transfer box. They all seemed okay and reseating them didn't seem to do anything.
