Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8589 |
1st Oct 2014 12:16pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Well my saga goes on and on.
1st Oct 2014 12:22pm |
Had a check of the trans box while I was fitting my side tubes today. All seems dry so far! Will keep an eye on it over the next few months. There is nothing that can't be fixed with a hammer😜😜
11th Oct 2014 1:30pm |
A1tony Member Since: 10 Aug 2016 Location: Surrey Posts: 4 |
Hi all.
10th Aug 2016 9:21am |
I think, and don't quote me on this that it may need plugging in to reset stuff when you swap or reinstall components.
10th Aug 2016 9:28am |
Many thanks.
10th Aug 2016 10:13am |
I had exactly the same problem with mine after re-build. It would not calibrate. I tried to reset it via a manual method (which I will try and find for you) and with a mates diagnostic tool which was quite advanced?
10th Aug 2016 3:44pm |
I have the same thing written on mine. Luckily I bought a spare transfer box so I could still operate whilst a refurbished my original. Sadly the chain is stretched in that but it does mean I have pretty much 2 of everything. I have seen some instructions for a manual calibration pressing the brake pedal and pressing he selector switch etc but it did t seem to do anything on my car.
10th Aug 2016 4:43pm |
I will try and find it. I printed off from a website somewhere! |
11th Aug 2016 6:57am |
Phew,!
11th Aug 2016 4:31pm |
👍 had a feeling that would be it. There is nothing that can't be fixed with a hammer😜😜
11th Aug 2016 6:37pm |
PHG Member Since: 20 Oct 2016 Location: Marple Posts: 15 |
Hi, I've just found this fantastic tear down thread.
20th Oct 2016 10:09am |
doesn't sound like a calibration issue to me. Not sure what is causing that, it could be a stretched chain in the box, Have you checked the CV joints, I wouldnt think that a transfer box problem would only be present when turning, I'm not sure that that would make a difference.
20th Oct 2016 3:28pm |
Hi thanks northern monkey.
20th Oct 2016 3:40pm |
