Home > Technical (L405) > front knuckle cracking |
elboss Member Since: 24 Mar 2021 Location: Dubai Posts: 5 |
This is the newely replaced knuckle
3rd Jun 2024 7:24pm |
Rio Member Since: 03 Jun 2024 Location: Albi Posts: 15 |
3rd Jun 2024 8:06pm |
This is only an assumption, but maybe the update of the knuckle corresponds to this molding difference? Or a pure coincidence? |
3rd Jun 2024 8:15pm |
As we see these knuckles, we even notice differences in models that have the rib on the same side!
3rd Jun 2024 8:46pm |
GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 16 |
Thank you for the photo compilation and observations. Very interesting |
3rd Jun 2024 10:42pm |
Coxy996 Member Since: 02 May 2024 Location: Buckinghamshire Posts: 7 |
Hi all, just seen Cristian and Vera's latest youtube video regarding the cracked hub carrier at the upper balljoint, seems the issue is caused by corrosion between the steel joint and alloy carrier expanding the alloy component. I have just checked my L405 (2019MY) and it seems on my car, after gentle cleaning with fine wire brush, the upper joints are shrouded in aluminium. |
11th Aug 2024 11:31am |
Hello Coxy996,
11th Aug 2024 7:00pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Was watching the latest LR Times youtube vid last night and Christans L405 has both (front) knuckles cracking. He said that he rang the dealer manager and he said he hadnt heard a thing about it from LR England. So he's going to put a submission into there motor authority about it and see what happens. He did say that it will probably be a while before anythings happens in the beaurocracy.
11th Aug 2024 9:21pm |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 31 |
So are many 2016’s affected as well?
12th Aug 2024 5:22am |
Yes. |
12th Aug 2024 7:40am |
Indeed, I initially thought about this update.
12th Aug 2024 8:16am |
But on the last photo that failed it looks like the sleeve is like ours in gray aluminum?
12th Aug 2024 8:18am |
Hi Rio, i've been trying to find out if the alloy sleeved joint is 2018my onward specific, not having much luck.
12th Aug 2024 10:34am |
It is indeed very complicated to have answers.
12th Aug 2024 11:45am |
