Home > Technical (L405) > front knuckle cracking
Page 40 of 47 <123 ... 394041 ... 454647>
Rio
France
Sorry for my low-level English, but can it be a track for upgrading the knuckles ?
The photo of mine 😥 identical to those who failed
Post #693850 3rd Jun 2024 4:01pm
elboss
United Arab Emirates 2015 Range Rover Vogue SE 5.0 SC V8 Fuji White
This is the newely replaced knuckle
Vs. the cracked one
Post #693858 3rd Jun 2024 7:24pm
Rio
France
Thank you, we can clearly see the difference in molding between the two
The rib of the molding of the failed versions goes in the direction of the bolt
The rib of the molding of the new versions goes to the opposite
Post #693859 3rd Jun 2024 8:06pm
Rio
France
This is only an assumption, but maybe the update of the knuckle corresponds to this molding difference? Or a pure coincidence?
Post #693860 3rd Jun 2024 8:15pm
Rio
France
As we see these knuckles, we even notice differences in models that have the rib on the same side!
When I compare your photo of the knuckle that failed with mine, there is already a difference.
But when I look at the new knuckle that they mount the difference is even greater!
I think there have been different upgrade or different suppliers over the years.
It would take a photo of the knuckles of the latest l405 MY 22 to see the model mounted.
Thank you elboss for letting me use your photos
Post #693861 3rd Jun 2024 8:46pm
GaryR
Australia 2014 Range Rover Vogue SDV8 Fuji White
Thank you for the photo compilation and observations. Very interesting
Post #693863 3rd Jun 2024 10:42pm
Coxy996
United Kingdom 2019 Range Rover Vogue SE SDV8 Carpathian Grey
Hi all, just seen Cristian and Vera's latest youtube video regarding the cracked hub carrier at the upper balljoint, seems the issue is caused by corrosion between the steel joint and alloy carrier expanding the alloy component. I have just checked my L405 (2019MY) and it seems on my car, after gentle cleaning with fine wire brush, the upper joints are shrouded in aluminium.
Post #697829 11th Aug 2024 11:31am
Rio
France
Hello Coxy996,
Are you talking about this aluminum sleeve?
Post #697853 11th Aug 2024 7:00pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Was watching the latest LR Times youtube vid last night and Christans L405 has both (front) knuckles cracking. He said that he rang the dealer manager and he said he hadnt heard a thing about it from LR England. So he's going to put a submission into there motor authority about it and see what happens. He did say that it will probably be a while before anythings happens in the beaurocracy.
littlecub
Post #697861 11th Aug 2024 9:21pm
ash83
United States
So are many 2016’s affected as well?
Anyone with this issue in the US can submit a complaint here:
https://www.nhtsa.gov/report-a-safety-prob...w.ds#index
This helps develop a recall.
Post #697862 12th Aug 2024 5:22am
Coxy996
Rio wrote:
Hello Coxy996,
Yes.
Post #697866 12th Aug 2024 7:40am
Rio
France
Indeed, I initially thought about this update.
The photo is that of my my 18.
And I found many other photos with a black sleeve:
Post #697867 12th Aug 2024 8:16am
Rio
France
But on the last photo that failed it looks like the sleeve is like ours in gray aluminum?
Post #697868 12th Aug 2024 8:18am
Coxy996
Hi Rio, i've been trying to find out if the alloy sleeved joint is 2018my onward specific, not having much luck.
This is my driver side joint.
Post #697873 12th Aug 2024 10:34am
Rio
France
It is indeed very complicated to have answers.
That's why I'm trying to find out if an update has taken place, by observing the different knuckle models.
The only difference comes from the molding as I mentioned above...
Post #697883 12th Aug 2024 11:45am
