![]() | Home > Technical (L405) > front knuckle cracking |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Bloody lucky it happened on your drive and not on the Motorway
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
I bet they try to blame potholes.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Looking at the new Defender today it was striking how much heavier duty the knuckle was, perhaps too much weight saving on the 405 and LR have realised that, especially in the context of a vehicle they aim at more off road use. Only Range Rovers since 1988 |
Brid91, have you owned the vehicle since new? |
Brid91 Member Since: 01 May 2019 Location: Rotherham Posts: 13 ![]() ![]() ![]() |
Update: JLR have rejected for the 3rd time stating 'outside influence' despite the independent report stating that there was no evidence at all to suggest this.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1367 ![]() ![]() |
Jlr really don't do themselves any favour with regards to further customer relations do they?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Look at it from JLR's side, the vehicle is 5 years old, it hasn't seen a main dealer for the last two services and they have no control over it's use, for all they know it could have been used to launch a boat in the sea on a daily basis, or some other extreme use.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
You must admit though, JLR leave a lot to be desired in their design and quality. Brake lines that can corrode on a car that supposedly can wade to quite a depth is ridiculous, they dont even have the excuse of trying to save money to keep the price down. Thats just one example. The knuckle failing dues to corrosion is not acceptable no matter if it's been to a dealer or not, the joint between the dissimilar metals wouldnt have been serviced in any way at all and if it was caused by corrosion, steps should have been taken during design or assembly to prevent this occurrence.
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
The problem here is not knowing the full history of the car from the time it was driven from the showroom by it's first owner. Without the part being examined fully it's just speculation about why it has failed. It looks dramatic and would certainly have been disasterous had it failed at speed but how many have actually failed? It's very easy to start to throw accusations towards JLR but we should wait until we have all the facts before we begin mud slinging. Yes they have a problem with customer service at times (not all MD's are as bad as each other) but they are no different to BMW, Mercedes etc to name but a few.
No matter what the history excpt for a major collision with that wheel there arent any circumstances where this can be deemed acceptable IMHO.
We don't know that this vehicle hasn't been involved in an accident since manufacture, not all accidents are recorded. No one is saying that this issue is acceptable but without the facts it's just guesswork as to why it has failed. All owners of the L405 will be following this with interest I'm sure but speculating on the reasons for failure serve no purpose in alleviating any concerns owners could have. As I mentioned before, how many of these knuckles have failed so far? According to this forum, none of the current L405 owners have had an issue with this component so it will be interesting to find out what exactly has caused this one to fail. 2011 TDV8 Vogue SE |
Needs to go to a metallurgy lad to determine the cause of the crack/failure.
Lab obviously but can't edit on phone |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Brid91
