![]() | Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Tomw
AMV Member Since: 09 Mar 2011 Location: EU Posts: 152 ![]() ![]() |
So the recall has been somehow officialized? A friend of mine with a TDV8 4.4 built in March has the same issue |
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 ![]() ![]() |
I'm not sure it is Official yet. But from what people seem to be hearing from their Dealers - the expectation is that something will be done to fix the issue at some point. I'll certainly update if I hear anything more. |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
The new batteries and software were in production from late February so your friend will not be part of the recall AFAIK. |
scene247 Member Since: 16 Sep 2010 Location: London Posts: 126 ![]() ![]() |
Think it might be official as I have had mine taken in on Tuesday, and had not suffered any problems to date. Was told the there was a notifiaction from LR last week and they needed to do this and other changes. Mine's one of the first MY2011 models I got in November.
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 ![]() ![]() ![]() |
Just got my official call to state my car is part of the "service enhancement program"!
Gents, thanks for the input.
Gerry, is there a reference number or a range of VINs which are to be "enhaced"? Santorini Black RR Vogue 4.4 TDV8 |
sorry,cant help with that, i just received a call from the dealer Gerry ____________________________________________ Arrived>Santorini/Jet FFRR MY11 TDV8 Gone>Stornaway/Ebony MY09 RRS HST TDV8 Gone>Java black/Ebony MY07 RRS HSE TDV6 |
The new battery and software that was available from early March is not working / fixing the problem.
Thanks anyway ![]()
Do you know if it has a specific version number or reference? ![]() |
Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 402 ![]() ![]() ![]() |
The issue is not a dealer one but a LR one as having had several conversations with my dealer, who I know watches the forums, their hands are tied by LR as to what they can and cannot do.
HJD Member Since: 09 Feb 2011 Location: High Leicestershire Posts: 22 ![]() ![]() ![]() |
I have a related question for the MY11 owners. I have never had the battery message nor has it failed to start but every now and then when I go to start it, depress the brake and press the button, nothing happens. The instrument panel lights up but the starter motor doesn't crank. However if I try a second time, it flies into life. Anyone else had similar? MY2011 FFRR 4.4 TDV8 Vogue, Santorini Black and Ivory *Arrived*
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
i had that happen when i had a flat battery, so had tried to start it 3 or 4 times then given up, put it on charge for a few hours then when I came back it obviously had power, seeing as all the gizmos switched on, but wouldn't crank. seems I had depleted the vacuum in the servo, and had to push down really hard on the brake to get her to crank. weird cos I thought it was just an electrical interlock, but perhaps there is a brake pressure signal that has to be seen to enable the cranking? |
so I had another fix yesterday......
