![]() | Home > Maintenance & Mods (L322) > Battery earth cable |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
i wouldnt pay that dealer price...have a browse on ebay , theres bound to be something on there.. ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
It could very well be the battery terminal, if you tap the top of the post with a small hammer all the way around the edge you can squish them down a bit and get them to spread out.... It's a bit of a bodge but should last a while...
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
i had simalar problem, earth clamp loose fit on terminal
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Search on eBay for battery leads, there are actual makers on there where you just tell them what you want, Ie length etc etc and they make it.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Thanks all. I'll look at that, and esp the quick fix, thanks ironhorse! Not sure how it could go from working to not, without being touched, but definitely worth a swift check. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 ![]() ![]() ![]() |
Piece of flattened copper tube inserted between the clamp and the battery post usually works. |
