Home > Technical (L322) > Where did that cloud of smoke come from? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
If it helps at all, I can definitely say that once the temperatures reach over 600 C, then soot levels fall over the next few minutes/miles quite rapidly, so much so that it is very difficult to grab screenshots showing what actually happens, but this picture explains what I believe is a correctly functioning Active regeneration.
8th Aug 2021 2:49pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
Dennis, Check your thermostat too. It may be over-reading as mine was.
8th Aug 2021 3:57pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
According to the IID tool my coolant temperature is reading 92 degrees but as you say, this could be mid-reporting. I can’t say that I have heard the fan running constantly but then I have had this issue for so long and the car appears so quiet when driven it’s hard to say. What I did notice was whilst waiting for the engine to get up to temperature after fitting the new coolant hose, the viscous fan was turning slowly rather than at full speed, I would say that means as far as that’s concerned it’s operating normally. 2011 TDV8 Vogue SE |
8th Aug 2021 4:27pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
Yes and I cleared my DPF today, took 20 mins from 19g down to 0.5 using the DA-DPF dongle. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
8th Aug 2021 9:49pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
After an extended test period I will update from our side soon... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Aug 2021 2:34pm |
New air filters
18th Aug 2021 5:27pm |
That's great news Rob, hopefully your friend can now fully appreciate his Range Rover.
19th Aug 2021 8:06am |
The only thing I can think that might have done it is the EGR and Turbo values cleared (or whatever he did) and/or ECU update.
19th Aug 2021 8:10am |
I have toyed with the ECU update via the service that GAP offer. Not sure how I could clear the EGR values though, would be interesting if anyone on here has done this or knows how to do it 2011 TDV8 Vogue SE |
19th Aug 2021 8:34am |
Take it to James at Henshall Engineering in Cheshire Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Aug 2021 8:49am |
Sadly too far away at around a 3 hour drive, I'd be at a red DPF by then 2011 TDV8 Vogue SE |
19th Aug 2021 10:43am |
That's when you call the AA Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Aug 2021 12:05pm |
Rob, I like your thinking 2011 TDV8 Vogue SE |
19th Aug 2021 12:53pm |
@GGDR
20th Aug 2021 6:28pm |
