![]() | Home > Technical (L322) > Where did that cloud of smoke come from? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 ![]() ![]() ![]() |
If it helps at all, I can definitely say that once the temperatures reach over 600 C, then soot levels fall over the next few minutes/miles quite rapidly, so much so that it is very difficult to grab screenshots showing what actually happens, but this picture explains what I believe is a correctly functioning Active regeneration.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 ![]() ![]() ![]() |
Dennis, Check your thermostat too. It may be over-reading as mine was.
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
According to the IID tool my coolant temperature is reading 92 degrees but as you say, this could be mid-reporting. I can’t say that I have heard the fan running constantly but then I have had this issue for so long and the car appears so quiet when driven it’s hard to say. What I did notice was whilst waiting for the engine to get up to temperature after fitting the new coolant hose, the viscous fan was turning slowly rather than at full speed, I would say that means as far as that’s concerned it’s operating normally. 2011 TDV8 Vogue SE |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 ![]() ![]() ![]() |
Yes and I cleared my DPF today, took 20 mins from 19g down to 0.5 using the DA-DPF dongle. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 ![]() ![]() ![]() |
After an extended test period I will update from our side soon... |
New air filters
That's great news Rob, hopefully your friend can now fully appreciate his Range Rover.
The only thing I can think that might have done it is the EGR and Turbo values cleared (or whatever he did) and/or ECU update.
I have toyed with the ECU update via the service that GAP offer. Not sure how I could clear the EGR values though, would be interesting if anyone on here has done this or knows how to do it 2011 TDV8 Vogue SE |
Take it to James at Henshall Engineering in Cheshire |
Sadly too far away at around a 3 hour drive, I'd be at a red DPF by then |
That's when you call the AA Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Rob, I like your thinking |
@GGDR
