![]() | Home > Technical (L322) > Where did that cloud of smoke come from? |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
My latest theory is that my vehicle is trying to regenerate but due to the sensor being faulty and over fuelling the soot is building up almost as fast as it’s burning off. As I say, just a theory but I definitely have the diesel smell around the car at idle so having it swapped out is no bad thing. Need to decide whether to tackle it myself or try and get an agreed price to have it changed |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
keep an eye on your fuel/oil immersion levels. |
Had some time today to prepare for the EGT Sensor change, following the advice on here I wanted to soak the sensor nut to aid with removal when the time comes. Armed with a mirror to get some idea of where I needed to be spraying I was surprised to find I could see the sensor nut clearly and could even touch it with my fingers (just). It would seem that either the sensor has been replaced before or someone has removed the heat shield covers as they are clearly both missing. Although I have to say that even though access to the nut is better than if the heat shields were in place, it's still going be a job I'm not looking forward to doing as access is still restrictive. While in that area I took the time to find the connector which I decided to unplug and see if the usual error code associated with this appeared, which it did so it looks as though the sensor is working to some degree, who knows, maybe it's working as it should. All the signs point to this being faulty though such as the diesel smell and the fast filling DPF, I have my doubts but considering I've had so many others parts replaced there isn't much left to try so I'll keep my fingers crossed and report back once the new sensor has been fitted and tested. 2011 TDV8 Vogue SE |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Existing fault may be either NO or NC, whichever it is may be the same as unplugging so all you need to do is try plugging in the new sensor
Freypal Member Since: 01 Jul 2022 Location: Shropshire Posts: 3 ![]() ![]() |
Hi, sorry to resurrect this but did you ever get a resolution to this issue Dennij?
Hi Freypal, I gave up in the end, ploughed way too much money into it and never managed to get a resolution. Sold it on to Cazoo 2011 TDV8 Vogue SE |
Ah, sorry to hear that |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Worthwhile removing the MAP sensor - they can get gunked up in diesels and also check for charged air leaks. Both these can cause a DPF issue and are relatively straightforward to check. Needless to say, I'd also extinguish the code and then go and drive the car at 60-70mph for 30 miles, with periodic hard acceleration from 60 to 70, to see if this forces the regen. The periodic acceleration will get the system nice and hot. Then I'd look to replace the exhaust gas temperature sensor, which being a 4 cylinder is probably a darn sight easier than down the sides of a 4.4L V8. 2015 Range Rover Autobiography 4.4 SDV8 |
Many thanks, some good things to check! I was tempted to just swap the EGT sensors since they're only £50 each and a quick swap. |
