![]() | Home > Technical (L322) > Where did that cloud of smoke come from? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
Dare I ask how much the new part was? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Not cheap that's for sure. I shopped around and the cheapest genuine part I could find was £483.54 This was for the latest incarnation of this part which seems to have been superseded many times over the years. It's a lot of money for a piece of plastic |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Very obvious |
Finally got everything fitted and ready to test. Took it for a drive down the motorway but sad to say the problem is still the same. Engine up to temperature and soot level slowly going up despite sensor 3 reading 615g Sensor 2 stayed around 450c. Oddly whilst monitoring the levels on the way back home I found that whilst driving at 50MPH on an A road that meant stopping at lights and having to drop to 30MPH twice due to speed limit changes, if sensor 2 read a higher temperature than sensor 3 the soot level would drop, albeit only small amounts. I left home at 19.5G and reached 20.6g on the motorway, by the time I got home I was reading 18.1g. So from that I think it proves that something is causing sensor 2 not to get up to temperature. On another note I stopped at a coffee drive through and could smell what appeared to be exhaust fumes? Hard to say exactly but it was definitely something other than unburnt diesel.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
What is your DPF pressure differential v reading ?
Hi Greg many thanks for your response
ok good yes that seems fine - this is effectively is your clog meter.
On my DPF posts there are screen grabs of a regeneration in progress if you want to check the sensor numbers / behaviour. 5 mins isn't right... But it does cycle. Actually the temps go up in steps. 400-odd, then 500-odd, then 600-odd. It will then drop sometimes to 580 then after a minute or two, go back up to around 630c .The whole thing will take 15-20 mins.
ok good, sorry I am sure you have said this, I didn't read back through your thread.
that should certainly be enough. Is it doing what I call "maintenance burns", loosing a few grams. Next suggestion I think is to get a DA-DPF tool which I bought and use, it's good and it loosens up the regeneration requirements, forcing a regeneration through the ECU. I am told the IID Tool does this now but I've not tried it. When you had the DPF cleaned, did you reset the DPF on the ECU? You can do this on the IID. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
The drop from say 620c will go down to around 550c at its lowest but rises again pretty much as you mention going back to 600+c in increments of between 5 & 10c at a time.
So how long is it burning at over 600 ? in total?
It will burn at 600c for between 5 - 10 minutes at best before dropping to 595, 590, 585, etc down to a low of 550c before climbing back up to a maximum of 620c where the process repeats 2011 TDV8 Vogue SE |
Forgot to say Greg that the DPF was reset upon refitting after the clean (Told car it had a new DPF via IIDtool)
if you add up all the 600 burn times ? because 3 or 4 of those should bring your soot to 5g give or take if 3-4 of those then the regeneration is actually working as it should. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
I’ll be providing an update soon on the family friend tdv8 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
@Rob and Dennis,
