Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 8 of 10 <12345678910>
Range Rover L322
Baltic, I am half way through this. I noted your advice not to let the piston drop whilst the saddle is removed (thank you!).
I have taken notice and am heeding your advice - but why? will the piston not pump back out?
all the best,
Post #568329 28th Sep 2020 9:55pm
GGDR
Fluid will leak out
. Cheers, Greg
Post #568331 28th Sep 2020 10:09pm
Baltic Blue
Greg Thumbs Up
Several members have reported difficulty recovering it to refit the top.
Post #568343 29th Sep 2020 6:44am
Range Rover L322
In case any use for someone .
Post #568432 30th Sep 2020 2:09pm
Range Rover L322
I have had an engineering firm make these - how beautiful is that!
You can probably guess how bored I am in Lockdown...
If it fits I will get the firm to make them and intro them to Stan etc so people can buy them pre-drilled.
Post #572079 7th Nov 2020 2:23pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #572090 7th Nov 2020 3:20pm
GGDR
Wow that is pretty special.
Mine is a bit more rudimentary, taking a "what's the fastest route from A to B" approach.
i.e. I didn't see much point of the disk element so how do I get a 16mm shaft to connect with a 28x58 odd mm hole.
So a 28x28x58 block of ally, drilled at the bottom, and a bit of excess cut off with an angle grinder to create the 'v' shape.
No welding, no machining (cordless drill too) so all done with hand tools if anyone wants to knock one up without much gear.
. Cheers, Greg
Post #572218 8th Nov 2020 9:15pm
Range Rover L322
Finished! just waiting for some 4mm slotted spring-pins to arrive.
these guys made the adaptor for me. Great job.
enquiry@anemboengineering.co.uk
Post #572274 9th Nov 2020 2:37pm
Range Rover L322
The nice guys at Anembo engineering are now producing the adaptor for the Mercedes Sprinter Jack ready made and fully drilled. Which we need since Baltic Blue moved and doesn't have his pillar drill any more!!
https://www.ebay.co.uk/itm/Land-Rover-Rang...SwfR5fyiKZ
Post #575058 4th Dec 2020 12:27pm
GGDR
£24 quid is pretty good for such a thing Thumbs Up
. Cheers, Greg
Post #575059 4th Dec 2020 12:30pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Would have save me a lot of effort and I bet their result is not "a bit wonky" like mine. Embarassed 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #575062 4th Dec 2020 1:23pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
New to the RR but noticed this thread. Interested in the bottle jack as my hydraulic one won't go high enough for this. Where can you get the Sprinter Jacks from, can't see on EBay. Presume the Sprinter one is the best option. Thanks for any pointers.
Post #575342 7th Dec 2020 10:41am
rjff
Search mercedes sprinter hydraulic jack
https://www.ebay.co.uk/i/284086083792?chn=...4129f441f0
Perhaps both a bit on the pricey side. Cheers
Richard
Gap IIDBT
Post #575346 7th Dec 2020 11:06am
Ricardo Villa
Thanks Richard, have found them! Yes bit pricey, will keep an eye out for some cheaper ones!
Post #575350 7th Dec 2020 12:11pm
rjff
Welcome Ricardo
Also well worth while keeping an eye out in for sale on here, got mine from a member. Thumbs Up Cheers
Richard
Gap IIDBT
Post #575355 7th Dec 2020 12:23pm
