![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
you can actually file the top down so its flat, that's what I did before welding the rectangle on the pressure is then not delivered via the "horns" |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Another one purchased |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
I got the ebay jacking adapter for this but it was resin rather than ali. Doesn't look like it will cope sitting on the bottle jack. Any one have any idea if you can get the ali jack adapter rather than the resin one?
TurboTim Member Since: 17 Oct 2013 Location: West Sussex Posts: 1 ![]() ![]() |
Steve
Errr.... Try the link in the post above. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
That looks like it would take your knuckles off! |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
I doesn't hit the knuckles as you have just enough angle. It's not 100% horizontal.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
That horizontal pumping jack would be really useful with the deployable sidesteps. Where would I find one? 2012 5.0L S/C
That looks like a silver coloured version of the composite ones I have but says its ali. Thanks. Current: RR L322 2010 Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB |
The Merc jacks are also hydraulic pumping jacks. Modifying the top with the adaptor is just to introduce the load of the jack into the car in a better way |
http://www.weberuk.com/ 2017 Range Rover Vogue TDV8 silicon silver 2011 Defender 90 2.4 TDCI Nara Exclusive 2008 Porsche 911 997 4S Black/black 1970 Porsche 911T 2.2 in restauration 1980 Toyota Land Cruiser BJ40 concours winner |
Thanks for that Gruute. I'll call them tomorrow. |
One more quick question: Does that Weber jack have enough lift to get a FFRR wheel off the ground: 385mm fully extended seems low? 2012 5.0L S/C
