Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 7 of 10 <12345678910>
DrRob
Mike - my thread will be using the Disco 2 bottle jack for roadside and SGS 3 tonne and adaptor for home work Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539919 9th Jan 2020 12:02pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Doing the same
I am also going through this and purchased the Mini jackpad, had it machined and replaced the top. Pictures attached. Found a machine shop here in Miami and had them do the work. Not sure if it will work - so need to try it. 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #539972 9th Jan 2020 6:07pm
pld118
Has anyone found a 'pad' that can be put on the bottle jack to make it L405 compatible (not used it since having L322s ans it's a waste)?
Apologies, if this is covered earlier in the thread/ just skim read so far.
Thanks
Post #539980 9th Jan 2020 7:39pm
DrRob
DrRob wrote:
supershuttle wrote:
I don't seem to have the option to upload pictures anymore it started but didn't finish, probably operator error Very Happy but when it comes back I will.
The key dimension is the rectangle viewed from the top should be 30mm x 55mm the 30mm is really tight but you could happily be a bit over on the 55mm - say 57mm maybe. Obviously if you get a measurement from someone who has bought the official BMW bit they would be the ones to use. Thumbs Up
Looks like 30mm is just right Thumbs Up
Going to order and then feedback. I have the SGS trolley jack..3tonne one
https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack
Adaptor will sit nicely on the rubber pad that came with the jack Thumbs Up
Pad has arrived. Feedback shortly in a new “DrRob jacking thread”
Post #541203 20th Jan 2020 5:28pm
Baltic Blue
Just a tip Rob, but make sure not to let the piston drop whilst you have got the saddle removed
Post #541208 20th Jan 2020 6:51pm
DrRob
Mike. Thanks. This adaptor is for using with my trolley jack. Pad to pad if that makes sense. I have a Disco 2 bottle jack for roadside wheel changing under the lower suspension arms Thumbs Up
I’ll get some photos and thread sorted soon Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541211 20th Jan 2020 7:14pm
DrRob
The pad fits perfectly in the sill slot Thumbs Up
This is the one I bought for reference. Same link as Greg's post earlier Bow down
https://rover.ebay.com/rover/0/0/0?mpre=ht...3884534748 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541263 21st Jan 2020 8:55am
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Anyone any thoughts on whether this would fit?
https://www.amazon.co.uk/iFJF-Aluminum-Ano...s9dHJ1ZQ==
Post #542999 4th Feb 2020 2:53pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
It'll fit the car, you need to mod it to fit the jack Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #543001 4th Feb 2020 2:59pm
Baltic Blue
You don’t. need to drill it all the way through, just deep enough to get the pin back in.
Mine is held on with a galvanised nail, just bent slightly to hold it firmly in place.
Mike.
Post #543006 4th Feb 2020 3:40pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Has anybody found a good place to buy a jack they all seem expensive on eBay
Post #543025 4th Feb 2020 8:32pm
M@r]{
Ok, my jack arrived the other day. £34.99 off eBay, brand new inc delivery. Rather than order the metal top a lot have done,
I thought I’d give a rubber one a try first, only £2.50 off eBay and a lot easier to drill Smile Anyway it arrived and got it to fit no problem. Should be kinder on the car too. I then ordered a small plastic tool box off Amazon, £5 delivered. All fits in quite nicely. So all in, brand new jack, new top to fit the FF and a box to keep it in and it all owes me just over £40 Smile Happy with that
Post #544493 19th Feb 2020 10:53pm
pcourtney
I found this in the back of our workshop today, a Weber Hydraulik 5 Ton bottle jack, I am going to file the ends off to have a flat surface and cut a 30mm x 55mm alloy rectangle 11mm thick or so, and weld it on for my L322
this is slightly differnet design to the newer ones, as the warehouse manager told me it's 15 years old to his knowledge
now to find a nice plastic box at home, put a torch in it, and some tools, and a bit of square wood to sit the jack on, and whatever else springs to mind
Post #557828 15th Jun 2020 7:57pm
Pawl
I've just purchased a brand new 2 stage 2T bottle jack on ebay for £40+ postage - as I couldn't find a Sprinter jack at a reasonable price.
https://www.ebay.co.uk/itm/Telescopic-2-To...2749.l2649
The jack arrived this morning and seems good quality and shorter than I realised - ideal for transporting in the car.
I think it could be ideal to be used under the suspension arms - where you don't even need a massive lift to get a wheel / tyre off the ground for removal.
I'll be testing it shortly when the rain stops !
UPDATE : The jack works well, easy to lift a wheel off the ground.
The handle comes in 3 pieces to make the assy very compact. The centre section contains 2 bolts to retain each of the other pieces.
However, the jack top pad is quite small & not ideal to use under the relatively narrow front suspension arms - too easy for the arm to slip off. The pad isn't removable, so not a simple mod to add a RR jacking slot compatible pad.
The low overall height, also means the threaded top piece has to be spun out maybe an inch to minimise "wasted" movement before the wheel starts to lift.
I think I'll be trying to create an adapter for the top pad to improve location on a front suspension arm. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #558280 19th Jun 2020 6:22pm
Range Rover L322
Duplicate deleted by author
Post #567883 23rd Sep 2020 11:47pm
