![]() | Home > Maintenance & Mods (L322) > Best adhesive for head lining |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
Unfortunately, this is a common problem with all cars of a certain age. The cloth roof lining is backed by a foam which deteriorates with age and slowly crumbles into dust. Applying adhesive to the cloth will not work as it wont adhere to the failed foam and backing board. The only real cure is to remove the roof panel, peel off the cloth and scrape off the old foam and recover with new material.
