Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 9 of 10 <12345678910>
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Ricardo Villa wrote:
Thanks Richard, have found them! Yes bit pricey, will keep an eye out for some cheaper ones!
Yes, keep looking on eBay etc. I got a new one from eBay complete with storage packaging for less than those secondhand ones! 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #575358 7th Dec 2020 1:36pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Thanks guys, will keep em peeled!
Post #575379 7th Dec 2020 3:19pm
Range Rover L322
yes that's my one photographed above, brand new still in the Mercedes styrofoam, I bought it for £40.
Post #575427 7th Dec 2020 11:00pm
Ricardo Villa
Yes at £40 I would be happy.
Post #575435 8th Dec 2020 12:37am
Range Rover L322
Here's one listed now for £40 on marketplace.
Doesn't include postage - however they will turn up if you have a look around
Post #575529 9th Dec 2020 12:57am
Hermes
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Had a puncture yesterday in the Mondeo... the Ford supplied scissor jack is far from the worst I’ve used but still felt flimsy and borderline unsafe.
Am going to get suitable bottle jacks for all my cars now
Post #575534 9th Dec 2020 6:47am
Ricardo Villa
Thanks, will have a look at that one. Cheers.
Post #575543 9th Dec 2020 10:48am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Think I've just ruined my jack attempting to fit one of these ebay blocks - my own fault BTW, nothing to do with the block at all which is a great quality item.
I got the original top off and when I went to fit the new one, I stupidly tried to tap it into place with a rubber mallet, which made the piston sink right down into the jack and it made a kind of gurgling noise as the fluid was sucked in somewhere. Now it has no strength at all, it pumps up in tiny increments with fluid coming out the top of the piston and it can be easily pushed back down with a hand.
Have I destroyed my jack, or is there a way to fix it does anyone know?
Cheers 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #591002 12th Apr 2021 4:15pm
Tugger
Well, at the risk of replying to my own post, I think I've solved it with the help of YouTube - seems it is easily fixable. I didn't have the new top piece fully attached hence why it was leaking, and it's just a case of refilling with fluid and bleeding the air out. Should be quite easy as it turns out, just need to get the correct fluid and should be fine. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #591012 12th Apr 2021 6:04pm
Ricardo Villa
Always nice when an easy fix is found! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #591034 12th Apr 2021 11:20pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Bottle jack
Hi
Does anyone know if the design of these jacks has changed more recently? The accessory unit does fit on a jack as described Mercedes Sprinter 2 1/2 Ton? Early posts here start 2014.
Thanks
Dave
Post #591188 14th Apr 2021 10:02am
Tugger
Dave - might be you are in the same position as me - the new block is a very tight fit (understandable since it needs to be a hydraulic seal) but it also seemed on mine like the hole might not be deep enough to get the piston in with the holes line up. I'm going to have another crack at it over the weekend to make sure
Same for you? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #591192 14th Apr 2021 10:36am
Nylands
Bottle jack
Thanks for your response and I was looking for confirmation that the ones advertised would work. The two items together aren't cheap but would be great for roadside use if they are compatible. Hoping you make progress at the weekend.
Dave
Post #591207 14th Apr 2021 12:58pm
Range Rover L322
. duplicate deleted by author.
Post #591237 14th Apr 2021 5:59pm
Range Rover L322
Hi Nylands,
I designed the adaptor that is available on ebay. Here are the dimensions. I suggest you buy the Bottle Jack then measure it before ordering if you are concerned about the fit. Please note I am not a pro, I make nothing from the sale of these, I just did it for fun and gave it to the engineering firm to fabricate mine then suggested they list them for sale.
[Also I accept no responsibility for injury or loss or damage of property, these are bought, fitted and used entirely at the risk of the user!].
Post #591238 14th Apr 2021 6:02pm
