Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 |
It looks worse than it is........... DIY and I can PM you my number if you have any questions... Pete
9th Feb 2016 2:14pm |
kineavy Member Since: 21 Dec 2015 Location: Cambridge Posts: 33 |
Trust me.....I am useless. |
9th Feb 2016 2:18pm |
What car have you got...??
9th Feb 2016 2:27pm |
Thank you for the kind offer and if you were closer then I would take you up on the offer.
9th Feb 2016 2:37pm |
jetset Member Since: 24 Sep 2015 Location: Bedford Posts: 10 |
Hi all,
19th Mar 2016 4:38pm |
sheps Member Since: 27 Mar 2016 Location: GB Posts: 8 |
Hi,
27th Mar 2016 12:11pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The reason that unit is cheaper that the other is that it is not an android unit It will do just about everything that the android will do with one exception you cannot add apps to customise the unit to your liking... basically if it doesn't do it though , But having said that if all your looking for is a functioning upgrade to the Range Rover system it will more than do that, with a lot more bells and whistles too
27th Mar 2016 1:03pm |
hi,
27th Mar 2016 1:26pm |
None of the existing system will work.... but that does mean that you can sell the cd changer, nav head , radio, amps, tv tuner, etc. but you will loose the clock setting function except by pulling the fuse and replacing it at 12 o'clock.
27th Mar 2016 1:37pm |
I think before you do anything you should read this thread and the other one with a link on page one and fully understand what you are doing and what you need, all the information you require is there.....
27th Mar 2016 3:12pm |
I agree with all the above, but for only a tiny amount more I would always choose the better unit, especially as the install of either is intense. As for the clock I have already decided that it's not needed and I will fabricate a two usb plug extension for iphone connection to go in it's place. |
27th Mar 2016 4:39pm |
hi, do you have a link or model number for the one that is a bit more ? i would rather get the right one first time, and would also like to be able to use the steering wheel controls if possible
27th Mar 2016 7:52pm |
hi again,
27th Mar 2016 8:11pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
As yours is touch screen which is MOST system you cannot use the above systems. John
27th Mar 2016 9:08pm |
