![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 ![]() ![]() ![]() |
It looks worse than it is........... DIY and I can PM you my number if you have any questions... |
kineavy Member Since: 21 Dec 2015 Location: Cambridge Posts: 33 ![]() ![]() |
Trust me.....I am useless. |
What car have you got...??
Thank you for the kind offer and if you were closer then I would take you up on the offer.
jetset Member Since: 24 Sep 2015 Location: Bedford Posts: 10 ![]() ![]() ![]() |
Hi all,
sheps Member Since: 27 Mar 2016 Location: GB Posts: 8 ![]() ![]() |
Hi,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
The reason that unit is cheaper that the other is that it is not an android unit |
hi,
None of the existing system will work.... but that does mean that you can sell the cd changer, nav head , radio, amps, tv tuner, etc. but you will loose the clock setting function except by pulling the fuse and replacing it at 12 o'clock.
I think before you do anything you should read this thread and the other one with a link on page one and fully understand what you are doing and what you need, all the information you require is there.....
I agree with all the above, but for only a tiny amount more I would always choose the better unit, especially as the install of either is intense. As for the clock I have already decided that it's not needed and I will fabricate a two usb plug extension for iphone connection to go in it's place. |
hi, do you have a link or model number for the one that is a bit more ? i would rather get the right one first time, and would also like to be able to use the steering wheel controls if possible
hi again,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
As yours is touch screen which is MOST system you cannot use the above systems. John
