Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 30 of 36 <123 ... 293031 ... 343536>
kineavy
Is there anyone Cambridge area that can and is willing to install one of these for me if I was to get one? Far to complicated for me.
Post #371432 9th Feb 2016 1:21pm
It looks worse than it is........... DIY and I can PM you my number if you have any questions... Thumbs Up Thumbs Up Pete
Post #371461 9th Feb 2016 3:14pm
kineavy
Trust me.....I am useless.
Post #371463 9th Feb 2016 3:18pm
What car have you got...??
Fill in the details on your profile then you will get a little car below your details in the box on the left, hover the mouse over it and up pops your details...
If you get totally stuck and can do without it for a few days you can drop it off here and I'll do it.... PM for info Pete
Post #371465 9th Feb 2016 3:27pm
kineavy
Thank you for the kind offer and if you were closer then I would take you up on the offer.
I have a 04 TD6 Vogue.
Post #371467 9th Feb 2016 3:37pm
jetset
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
cambridge
Hi all,
I am eventually playing at upgrading my head unit, having had the new one sat in a box for 6 months! (house move, work etc), but 'cos I want the sub to work I will install a 6 channel amp and crossovers (will better protect the speakers from giving them the wrong frequencies)....Will keep posted but I am near Cambridge (St Neots), so when fitted Kineavy can come and judge, if you like I can fit for you, but let's not get carried away until mine works!
Post #378350 19th Mar 2016 5:38pm
sheps
Hi,
ive had a look at the Erisin ES1153B 7 although it says for x5 i assume its ok for a 2004 rr ?
can you buy an add on to make it DAB ? and do i need extra caballing ?
many thanks for any help PS why is it so cheap lol
alex
Post #379621 27th Mar 2016 1:11pm
miggit
The reason that unit is cheaper that the other is that it is not an android unit Shocked It will do just about everything that the android will do with one exception you cannot add apps to customise the unit to your liking... basically if it doesn't do it though Shocked , But having said that if all your looking for is a functioning upgrade to the Range Rover system it will more than do that, with a lot more bells and whistles too Thumbs Up
As for DAB I don't think that Erisin produce a DAB unit at all.... that's not to say that you couldn't add one via the aux input but you'd end up with a separate controller for channel selecting Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379627 27th Mar 2016 2:03pm
sheps
hi,
thanks for the reply, didnt but read the listing properly, but as you say the android part isnt needed for me, it also says the steering wheel functions will still work which is cool, not sure if the multi changer will still work ? will i need any other leads ie: longer power cables or ariel leads
still very impressive price, when you compare to whats on flea bay
cheers, alex Thumbs Up
Post #379628 27th Mar 2016 2:26pm
miggit
None of the existing system will work.... but that does mean that you can sell the cd changer, nav head , radio, amps, tv tuner, etc. but you will loose the clock setting function except by pulling the fuse and replacing it at 12 o'clock.
Failing that you can ditch the CD changer, move the nav screen / midi unit to the glovebox and use a cd emulator to connect the new unit, but it is doubtful as to whether the steering wheel controls will work with the new unit.... but you will still be able to use the DSP from the factory set up... handy if you've got the logic 7 system Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379630 27th Mar 2016 2:37pm
I think before you do anything you should read this thread and the other one with a link on page one and fully understand what you are doing and what you need, all the information you require is there.....
The non Android ones (and some of the early Android ones) have very small processors and the speed of them will probably irritate you...
You get what you pay for............ Pete
Post #379654 27th Mar 2016 4:12pm
jetset
I agree with all the above, but for only a tiny amount more I would always choose the better unit, especially as the install of either is intense. As for the clock I have already decided that it's not needed and I will fabricate a two usb plug extension for iphone connection to go in it's place.
Post #379662 27th Mar 2016 5:39pm
sheps
hi, do you have a link or model number for the one that is a bit more ? i would rather get the right one first time, and would also like to be able to use the steering wheel controls if possible
many thanks, alex.
Post #379679 27th Mar 2016 8:52pm
sheps
hi again,
firstly sorry for the questions.....my rr is 2005 but only just (January 2005) my sat nav screen is also a touch screen does this make a difference to wiring or head unit needed ?
i have been reading a lot but think im starting to confuse myself Confused
cheers alex.
Post #379682 27th Mar 2016 9:11pm
Weegie
As yours is touch screen which is MOST system you cannot use the above systems. John
GAP iiD BT-Sold
Post #379685 27th Mar 2016 10:08pm
