![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
It is highly unlikely that the steering wheel functions will work, as your system is optically connected , were as the older system is linked via canbus... AFAIK the later cars don't have canbus |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8527 ![]() ![]() ![]() |
Pretty sure the canbus system is different when the BMW engined cars ended so no, I don't think it will work with the steering wheel buttons... Pete
It just uses signals on the canbus system but the head unit is talking German and the car talks English so they won't work... It's not just a system that does the steering wheel controls it's used for all sorts.... Pete
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
I've had a skim through the thread and it's left me pretty confused
You can't fit the flat panel ones that protrude from the dash, the FF dash has the overhang from the top crash pad and this will stop you fitting it, the latest one you want is this one AFAIK...
Thanks Pete , much appreciated |
Ottar Member Since: 07 Jun 2016 Location: Bekkestua Posts: 8 ![]() ![]() ![]() |
Hi again Pete.
Nigelpugh Member Since: 16 Mar 2018 Location: Solihull Posts: 21 ![]() ![]() ![]() |
Hi Ottar,
On the dsp amp in the boot, I assume that it has the big connector, for power and audio inut, and the two smalller connectors being the output to the speakers?
seewolfe Member Since: 22 May 2018 Location: Huntingdon Posts: 8 ![]() ![]() ![]() |
Hi,
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Good luck Mr Seewolfe. |
davidsmith1307 Member Since: 05 Mar 2015 Location: Hull Posts: 52 ![]() ![]() |
Good luck. Sure you'll get plenty of encouragement and as much shared knowledge as the forum has to spare. |
Since I took delivery of all the bits from Eonon today (ordered Tuesday), I decided to have a crack at a test install in the boot to ensure I understood how everything connected.
Well done seewolfe, you got further than me, I have a working unit but still no sound.
