Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 3 of 36 <123 4 ... 343536>
alahmed
Saudi Arabia 2004 Range Rover HSE 4.4 V8 Bournville
Hd Eyes Very Happy
we all do not have them anymore , that was before many years ago.
we need something like this Now
its very clear that you have achieved and completed more than one project on you car , good job man Thumbs Up
also i have noted in the picture you have included that you are using the new flip key , and maybe you could help also in this issue.
I have one like that, but because i was not able to find the correct position where the internal chip should be installed , i was not able to start the engine till now, so i am still using the old key.
my friend thank you so much in advanced
Post #277923 28th Aug 2014 8:02pm
see this page for how to program the key and install the chip
http://www.fullfatrr.com/forum/topic18624-105.html
page 8 half way down... all thanks to the key master daveo.... Pete
Post #277943 28th Aug 2014 10:58pm
alahmed
Lastly , Done
Thank you so much
Post #277951 29th Aug 2014 12:27am
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Haylands wrote:
John,
It wires/plugs in to the original wiring. I had more work to do as I removed the amp, the 12v acc and 12v batt are in the plug already, it then has an earth and a 12v out for the aerial amplifier, they had the panel lights wired to the can bus box but this didn't work on mine so I wired them into the rear near side, side light as it's next to the rest of the wiring in the boot, the side lights aren't on can bus so no faults or problems with that.... then the speakers. Have no errors at all and everything works fine. You do need a long aerial lead to get from the head unit to the boot....
I cut and soldered the wires but it is totally reversable to return to stock.
Just sold my old head unit and GPS DVD (both were working perfectly) for £305 on eBay so it's cost me £25 so far !!! Very Happy Very Happy
started to install this tonight and have an issue with the connector Sad
this looks like the one supplied
pulled the one out of the amp and the tunner and there is no way they will fit
so is it the wrong one ??? or am I looking in the wrong place ????
paul
Post #279318 5th Sep 2014 8:39pm
It plugs into the radio plug, radio is the small one furthest into the boot and furthest towards the middle of the car, I removed the plastic panel on the boot floor that the removable boot floor sits on, remove the tie down strap in that corner, then the two net hooks on the rear piece (they twist 90deg to remove) then remove small panel that runs up the inside of the boot opening, remove net hook at bottom of subwoofer cover, then boot floor plastic is three 10mm plastic nuts.
If you have small hands you maybe able to get the radio plug out without doing all that...
Sorry, I'm away for the weekend so haven't got any pics with me... Pete
Post #279373 6th Sep 2014 6:08am
mjdronfield
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #279383 6th Sep 2014 8:25am
hex
All
Thanks been a great help and Bow down its nearly in Thumbs Up
Post #279451 6th Sep 2014 5:11pm
hex
Not happy Big Cry
All in everything back the way it should be
But .......
Forgot to plug the radio areal in Big Cry Censored
Post #279631 7th Sep 2014 7:48pm
You need a 5 meter aerial lead and a fakra convertor to sort the aerial out, there is a standard plug in the back of the new unit, but the aerial is in the boot.....
Get a good quality shielded cable or you will get interference, I got a 4mtr and 2mtr one from Halfords and there rubbish.... I'll be changing them soon... Pete
Post #279688 8th Sep 2014 8:55am
hex
Got the lead from maplins, twin shield coax, it was 3.39 p/m and the connectors were £1.50 each Smile
Had it all working before I did the final routing of the cables, just forgot to plug it in to the head unit Censored Big Cry
I did remove the centre dash speaker ( under the grill) I am now thinking I could cut that and get to it and make a bit to replace the grill to present the cables I want, usb etc , and house a forward cam.
Paul
Post #279691 8th Sep 2014 9:29am
hex
for anyone else with one of the Android units who is having a few issues
"SD card unexpectedly removed "
1. Insert the USB memory stick / SD Card into computer.
2. Format it as ExFAT in normal way [uncheck the Quick Format box]
3. Go to you car and insert it into the unit.
4. The unit will see the drive but it will ask you to format it. Press FORMAT.
5. From this point, it will work.
access to the factory settings so you can change the start up splash screen is 126 Smile
Post #279913 9th Sep 2014 12:39pm
Nilrem
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
@Haylands I have an '02Vogue with DSP and would like to mirror your install but add the TV tuner.
I am about to contact the eBay seller (easyrising88)and would be greatful if you could confirm exactly what you bought so I can get my order right first time pls.
I see an option for an extension lead,power lead and canbus decoder and am not sure what I'll need.
Also if you do have any advice regarding the install and don't mind,could you forward them to me pls (nilrem280@gmail.com)
Thanks in advance
Post #280076 9th Sep 2014 9:04pm
Sorry, never noticed your message
you need the latest head unit, they seem to bring new ones out all the time, you also want the extension lead, which comes with the can bus box.. and they do a TV box with aerial
You will also need a 5mtr shielded Aerial lead for the radio and a standard to fakra connector.
Where in the UK are you?? Pete
Post #280441 11th Sep 2014 6:40pm
Nilrem
Hi mate,thanks for replying. I'm down south in Portsmouth.
I'm currently corresponding with 'Penny' from easyrising88 to order an ES9753EU head unit.
They list an extension lead,power lead and canbox all as extra's , so if you could confirm exactly what you ordered I'd be grateful.
I'm pretty handy with a soldering iron so don't expect any issues 'but' I'd appreciate any pointers you do have as there is a lot of wiring back there to sort through.
Cheers Pete
Post #280454 11th Sep 2014 7:32pm
I went through Erisin themselves, I think easyriding sell their stuff...
Try Crystal at erisintechservice@erisin.com
Power lead was within the extension lead, comes with a short lead as standard with a canbus box, get the long lead and the canbus box plugs into that, it's then plug and play with the radio plug in the boot, you need the later 40pin extension lead...
Email Crystal and tell her you want what Peter Hitchcock had plus the TV tuner, she will sort you out.... Pete
Post #280486 11th Sep 2014 11:58pm
