Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
number 4 looks like a smb connector for a sat nav antenna... ... - .- -.
8th Feb 2013 11:40am |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 |
Ok, thanks starting a new thread not to hijack my own 2008 TDV8 VOGUE - Buckingham Blue on Sand |
8th Feb 2013 11:43am |
So, I've disconnected the plug and Surprise, doors looking works so it's good in the sens that I can have the car locked but bad in the sense that I still have many things I don't know about that will be consuming energy.
8th Feb 2013 6:47pm |
Thanks but the thing is I don't have satnav 2008 TDV8 VOGUE - Buckingham Blue on Sand |
8th Feb 2013 7:27pm |
So the result this morning is that the car was @11.5, could not be remotely unlocked. I've had to go into the trunk from the interior of the car
9th Feb 2013 11:06am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
One question, when I recharge the battery, is it ok to only remove the -ve or +ve but not both?
9th Feb 2013 5:10pm |
Ok for the charging method (can it be the +ve also?).
A test I should do is let the car in a some place far from the antenna for half a day and check what happens to the battery. I'll try to do that tomorrow. 2008 TDV8 VOGUE - Buckingham Blue on Sand |
9th Feb 2013 6:27pm |
Yes you can take the +ve off for charging.
9th Feb 2013 6:32pm |
ok, thanks, the post has really grown big ( http://www.fullfatrr.com/forum/post164685.html#164685 ) 2008 TDV8 VOGUE - Buckingham Blue on Sand |
9th Feb 2013 6:58pm |
DBMONKEY Member Since: 02 Nov 2011 Location: Kent Posts: 6 |
Hi all, been following this thread closely for a number of weeks. Had issues around Xmas time with the car not starting randomly and diagnosed faulty alternator.. Since replaced but still every 2-3 days would need to jumpstart it. Battery is the s5 Bosch only put in last year. Took it to dealer this week who could not find anything wrong with it and returned it to me as is.... So finally got round to checking fuses this morning:
10th Feb 2013 5:26pm |
One key missing part is after how long did you do your tests and were all doors closed?
10th Feb 2013 8:07pm |
The car is now at the LR dealer, they were not really interested in understanding my investigations since "they perfectly know what they're doing" in the spirit. We'll see that, they'd better find the issue and fix it now 2008 TDV8 VOGUE - Buckingham Blue on Sand |
13th Feb 2013 11:09am |
Called yesterday and they are the stage of putting a new battery after seeing that indeed the battery has lost power over the week-end. I'm not close from seeing my car repaired... 2008 TDV8 VOGUE - Buckingham Blue on Sand |
19th Feb 2013 12:45pm |
Almost 2 weeks at the dealer... What they say: The see NO consumption at all... The car continuously starts without any issue. I'll get it back tomorrow.
25th Feb 2013 3:08pm |
