Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 11 of 13 <123 ... 10 111213>
Ibartsimp wrote:
- All my tests were done with bonnet not completely closed, could this be the consumption source?
disconnect the bonnet switch and try your tests again.. ... - .- -.
Post #174483 25th Feb 2013 3:11pm
I checked the situation both with the bonnet open and bonnet closed, made no difference either way to the car going to sleep. Thumbs Up
Be interesting to see how things go when you get the car back home. Thumbs Up
Post #174485 25th Feb 2013 3:15pm
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
In this case, would be the interferences. I'll go to the ski next week, with it. I'm taking risks, but we'll see. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #174486 25th Feb 2013 3:17pm
Ibartsimp
Should I laugh Rolling with laughter or should I cry Big Cry? You decide. Here are my latest adventures.
The discussion @ the LR dealer
- Monday: Sir your car will be ready tomorrow, we found nothing, all is ok
- Tuesday: You can come and pick it up
- Wednesday morning (I was too busy on tuesday): OMW to the dealer, call on the phone. Sir your car doesn't start this morning. Your battery is completely dead and indicates 8V... So it was indeed the battery that was faulty. me: Hum, I don't think so but if it's all you can do, go ahead and change it if you're sure it's dead.
The workshop chief tells me the following:
- When a battery is flat on this kind of cars, we never recharge them because it means it's dead (differs to small cars, differs also to old batteries, he told me…)
- We've done a hell lot of research on your car and it continuously started wihtout issue (after checking with the mechanic, battery was disconnected from the car most of the time, for testing)
Continuing with the mechanic:
- We've seen no drain, tends to 0.01A after 30 mins (great, what I had already explained)
- Me: did you plug a logger? => No, we don't have one.
- A car can't magically turn things up during the night besides what's scheduled
- Me: have you heard about FSR drain. => Nope (note that I didn't know the french word for FSR). I tried to explain but didn't ring a bell
Well, 650€ less in my pocket (4h of diag, 1 batt, 1 replacement of a coolant hose), I leave the dealer and get back home, quite sure my issue isn't solved.
Since then
- Went back home: old battery was at 11.something (don't remember) but not 8… Put it in charge and will see
- Overnight, the car lost 0.4v (from 12.6 to 12.23 this morning)
- At the office, which is really far from the supposed antenna
10h: 12.53 (but doors were not locked until 14h20)
14h50: 12.23
15h50: 12.23
17h10: 12.22
18h10: 12.21
Here's where I stand.
Overall feeling: The competency of the LR dealer is low, the honesty isn't flying high (hope I'm wrong on this one)
My car still has a nasty issue probably linked to the antenna near my house?
If I want to treat the RFI, any other options than the cleaning & waxing all grounding points as mentioned here?
ebajema wrote:
It might pay to get all your ground points cleaned and "Vaselined" as good grounding can help in avoiding RFI problems (although in vessels/ships there are two "schools" the ones that tie the RFI cable shielding to ground and the ones that don't).
Joe90 wrote:
Earth points: all brown wires, usually many together at these points:
Just to make sure I understand, all numbers above represent grounding points? Are they all beneath the car on the chassis or on other fun places? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #174998 28th Feb 2013 5:12pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Great story... had wrote and asked about your telefone and your resistor. Have had exactly the same problems, each two years new battery, the old one in company car, and all is good! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #175330 1st Mar 2013 10:23pm
@ Ibartsimp
If you pm me your email address I will send you a file showing the location of all connectors on the car by number including earth points. Thumbs Up
Post #175352 2nd Mar 2013 9:36am
Ibartsimp
thanks so much, for your proposal, pm on its way 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #175354 2nd Mar 2013 9:46am
Ibartsimp
Hi all, some news:
I've been able to locate the earthpoints thanks to the doc sent, thanks.
On monday I found my battery completely dead (the old one) with only 8.5v. Maybe constantly being discharged then recharged killed it?
Decided to change it, went for a generic 90A one since I was in a big hurry to get the car ready for going to ski.
Went to ski, 500kms away, observed the battery draining itself at the pace of 0,04v / hour.
I guess I don't suspect Radio Frequency Interferences any more?
=> Back to square 1 Big Cry 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #176714 9th Mar 2013 9:23am
ebajema
Was just about to ask how things were going. Sorry to hear that it is still not resolved. MY 2010 5.0 SC Galway green and sand interior!!
Post #176715 9th Mar 2013 9:29am
Sorry to hear you are still having a problem.
It obviously isn't external interference causing the problem.
Is the battery still draining now you are back home?
0.04V / h drop in voltage on the battery is a lot and is unsustainable.
In view of the amount of checks you have done to date I simply don't know what else to suggest unfortunately.
If I think of anything I will come back to you. Thumbs Up
Post #176748 9th Mar 2013 11:44am
Ibartsimp
I haven't tested if the battery was still draining but I will later today.
One crazy thing is that my old battery, after resting in the garage for a few days now indicates 11.17 (indicated 8.5 on monday). How is this possible? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #176750 9th Mar 2013 12:14pm
ebajema
Normally that indicates that the battery is f Censored cked. Wasn't this one new ?? Not that that is a guarantee, even new ones can fail in days/weeks (don't think it happens a lot but have heard it).
Post #176758 9th Mar 2013 1:09pm
Ibartsimp
One thing I'm thinking of doing is plugging an ohmmeter that has logging capability and see what happens. Maybe the consumption pattern will be familiar and allow to identify the faulty part. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #176817 10th Mar 2013 8:38am
Ibartsimp
Well, still haven't bought the ohmmeter with logger, but I did an interesting thing yesterday night:
- Removed all fuses in the glove box
- Lost 0,06V in 8.5 hours => 0,008 / hour => 0,19 / 24hours
If this comes to acceptable (tell me what you think), I'm going to do dichotomy tests and unplug only half of the fuses tonight and so on to narrow to the faultive ones.
forgot to mention that while putting back all fuses, it turned out that one 5A fuse was replaced by a 30A. Changed back to a 5A. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #177509 14th Mar 2013 9:39am
Ibartsimp
Progress...
Post #178057 17th Mar 2013 5:35pm
