Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 2 of 13 <123 ... 111213>
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Is the ammeter set correctly? 0.5A may be ok ideally 0.3-0.2A 5A is quite a lot One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #163920 12th Jan 2013 1:32am
A significant battery drain thro the alternator would be well within the 5A range of an ammeter. I would expect the drain to be in the mA range.
Post #163940 12th Jan 2013 9:28am
OK Thanks. I have milliamp ranges but the highest setting (when you switch the red plug to a new socket) is 5A as opposed to 10A on Ibartsimp's meter. Thumbs Up .
Post #163961 12th Jan 2013 11:53am
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
was going to do, but now I'm locked out of the car Sad me very Big Cry
http://www.fullfatrr.com/forum/topic15916.html
Post #163987 12th Jan 2013 2:10pm
Ibartsimp
back to the topic, I havent been able to do the tests but will tomorrow.
Can we conclude anyway that I have a serious battery drain. In the process I had bought a new battery but I guess it wasn't the issue...
Post #163999 12th Jan 2013 2:58pm
It does appear you do have a serious battery drain.
As previously, check for posible alternator drain first.
If that is not the cause of the current drain it will be a case of checking each circuit on the car until you find it.
When you get back in the car one thing you could check, are the battery terminals fully tight?
Post #164003 12th Jan 2013 3:23pm
Ibartsimp
So I managed to get inside the car, had it wired to my defender's battery for 15 minutes, then unplugged the defender, connected the ohmmeter between these two guys inside the green dots.
Result: nada, nothing, 0.00 on the meter, be it set to 10A or 200m
EDIT: oops just realised (after I went testing my other battery) that the hold button of my meter was pushed Sad will test again tomorrow.
btw, I did a forum search on the word "drain" that I had forgotten and got quite interesting threads
Post #164052 12th Jan 2013 5:27pm
Ibartsimp
Battery (thought was faulty) now fully charged & delivers 13v. Am I right in thinking it's ok?
If so I'm gonna swap. Do I really need to go through this procedure?
http://www.fullfatrr.com/forum/post67804.html#67804
Post #164160 13th Jan 2013 8:56am
No you don't need to go through that procedure.
Just connect the cable back onto the jump stud.
Start the engine and turn the steering wheel fully lock to lock both ways.
After charging a battery will tend to read a high voltage due to surface charge.
The battery voltage will drop to about 12.6V during the day.
It shouldn't drop below about 12.5V to be useful.
It's difficult to get an accurate measurement without a permanently installed voltmeter readable outside the car as each time a door is opened it wakes up the car and the voltage drops due to all the ecu's switching on.
You will just have to wait and see if the battery now drains again.
Post #164161 13th Jan 2013 9:18am
Ibartsimp
Hi, here are the (bad) news:
- The battery while not plugged to the care was at 12.8
- Connected to the car, it's now at 12.3 (but I had doors opened & tutti cuanti) so I suppose I have to close all but I just remebered, getting back to the computer...
And the ohmmeter detected 0.
The really bad news is that the car doesn't start at all, barrel doesn't unlock Sad
What can I do?
Post #164301 13th Jan 2013 3:59pm
I' assume you found no drain to earth through the alternator?
If so you either have a faulty battery or a significant drain through a circuit or circuits on the car.
I would recharge the battery and then remove fuses 49, 34, 64 and 22.
These will isolate the Final Stage Resistor on the ac, the radio/satnav and the telephone.
I'd be inclined to think one of these circuits will be the source of the main current drain.
Post #164307 13th Jan 2013 4:08pm
Ibartsimp
I put the ohmmeter with each end on each part highlighted in green. That's the only test I did. How do I test the drain you talk about?
Nope, I've bought a new battery and had the same symptoms (was a 100amps instead of 110 though).
I'll try that (removing the fuses), they are in the trunk, correct?
Post #164312 13th Jan 2013 4:14pm
I assume you had your multimeter set to 10A when you tested between the points marked with green circles and the reading was "0".
The fuses are in the box behind the glove box on right hand drive car, don't know about left hand drive.
Fuse 64 isn't marked but is the large red 50A fuse at the right hand side of the fuse box.
Post #164319 13th Jan 2013 4:24pm
Ibartsimp
Correct. My bigger issue now is that the car won't start at all.
And yes the fuses are in the glove box.
Post #164333 13th Jan 2013 4:58pm
Probably battery flat again.
Have you checked the battery terminals are tight?
Also, although you have a new battery I would get it's condition checked.
You have a significant current drain somewhere which could be internally in the battery.
Post #164335 13th Jan 2013 5:11pm
