Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 3 of 13 <123 4 ... 111213>
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
When my FSR went it was so hot after being parked for about 3 hours it burned my guys hand !!!! so if you can get near it and its hot after the cars been switched off a while thats your problem. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164347 13th Jan 2013 6:40pm
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Connections are and were tight
I've had the same issue with both batteries (old and new one)
I'm currently recharging the old one that's again in the car, for the night, I'll see tomorrow.
WHat's strange is that last time I've had the flat battery, plugging the cables from another car did the trick at least to start it. Now it doesn't.
Post #164359 13th Jan 2013 7:18pm
JohnnyDangerous
You could check the cables from the alternator for resistance. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164360 13th Jan 2013 7:19pm
Ibartsimp
So after several investigations, battery's not the issue, resorting to this (direction LR Approved garage)
Post #164594 14th Jan 2013 3:13pm
still looks good even on the back of a low loader... Thumbs Up ... - .- -.
Post #164600 14th Jan 2013 3:23pm
JohnnyDangerous
Did you check the FSR ??? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164601 14th Jan 2013 3:23pm
Ibartsimp
No, didn't check the FSR (I didn't know what it was but I have now done a search and see). Will point that to the indy.
ps: reason for not checking is that the rangie won't start now even with a full proper battery, with cables or whatever.
Post #164609 14th Jan 2013 3:40pm
JohnnyDangerous
Youve not had a lot of luck have you ??? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164613 14th Jan 2013 3:51pm
Ibartsimp
Laughing you can say so, I have several small things to fix BUT
engine & gearbox work very well & I did get it for a (too?) good price.
I hop to strike a deal with the seller on work to be done or he will have my lawyer on this a$$$
Post #164618 14th Jan 2013 4:12pm
JohnnyDangerous
Has it gone to a RR specialist as TBH now ive had one for a couple of years even a very good garage will struggle with the intracasies of a FFRR unless they have experience. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164636 14th Jan 2013 4:44pm
Ibartsimp
They are LR specialists, not RR... If he proves not to be competent, wil go to the dealer (there are 2 in my area)
Post #164640 14th Jan 2013 4:51pm
Ibartsimp
Ok, they are such good specialists that even the Range knew it Laughing
The boss put the key in the barrel and the car started immediatly (so he just told me on the phone)!
So he tells me that RRs can be bothered by interferences from TV antenas (the ones that broadcast) and it's true that my village has a big one... and sometimes moving just some hundred meters solves the issue.
Ever heard that?
He will now investigate on the battery drain. Will keep u posted.
Post #164685 14th Jan 2013 6:41pm
JohnnyDangerous
I thought that was the P38, that was quite commom on those. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164686 14th Jan 2013 6:45pm
Ibartsimp
Now that you say it, I think I remember the same guy telling me the same thing about my P38 (I've had 5 btw Wink)
Post #164687 14th Jan 2013 6:49pm
JohnnyDangerous
What about the current drain? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164688 14th Jan 2013 6:50pm
