Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 13 of 13 <123 ... 111213
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Well, I don't know what a clampmeter does but...
I've changed my FSR on fri 12th, went 4 days abroad (main fuses off by security).
I've used the car almost every day since then and did not have the chance to do extensive tests. Only done a few and saw once that voltage was still dropping, and once that voltage was not.
What I don't know is if a battery has to be around 12.6 all the time or if it can drop around 1.40 without this being anormal (new battery, 90A, no specific brand) 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #184034 22nd Apr 2013 1:08pm
Ibartsimp
I realize that I haddn't got back here. THe problem was solved by changing the FSR!
For some reason, I received a PM and my mailer spammed it (so just discovered today). 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #221415 7th Nov 2013 11:46am
Mrmerlin
2005 Range Rover HSE 4.4 V8 Giverny Green
Bart thanks for updating this post glad you replaced the FSR
Post #221452 7th Nov 2013 2:32pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Been reading the dead battery saga with interest as my recently purchased 2008 TDV8 Vogue has suffered a discharged battery overnight on 3 separate occasions in the last month. Have a new Bosch 110A battery on order as mine is, I think, the original so 5 years old. Do I understand that replacing the FSR has now completely cured your dead battery problems?
Post #221499 7th Nov 2013 7:00pm
Ibartsimp
Yes completely solved. 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #221509 7th Nov 2013 7:39pm
billcyn
Excellent news and hope you now enjoy some trouble free Range Rovering
Post #221535 7th Nov 2013 11:08pm
supershuttle
Before I rush out and buy a new FSR - did it exhibit any other symptoms?
I just get the occasional dead battery but blower and fan seem to be fine. Geoff
Post #221538 7th Nov 2013 11:13pm
