![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Have you tried using one of these http://www.maplin.co.uk/automotive-current-tester-217879
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
No, i did'nt. But I've done many drain tests from the earth on the battery, seeing no drain.
I get the overall functionning but why would I see a drain in the fuses I don't see (with all fuses in) when testing the drain from battery -ve to earth jump stud? 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Useful little device, I use one. |
yes but to test the fuses individually one after the other I need to be in the car and do the swaps, but that's anecdotic. real question is above.
You wouldn't.
Now I agree |
Well I still have a drain, even with fuses 22 & 49 and venture cam off
You're not having a lot of luck.
Well, let's say I have one f.. hard drain to locate. The rest is fine and I'm very pleased to discover that I have a venture cam.
is. In the engine bay, inside the car and if so, where? 2008 TDV8 VOGUE - Buckingham Blue on Sand |
In the rear loadspace side compartment, opposite side to radio etc.
adesmith Member Since: 06 Feb 2013 Location: Cheshire Posts: 46 ![]() ![]() ![]() |
I have the same issue and will try this tonight. The easiest tell for me as to if the battery has drained is that the screen takes a few mins to come on after startup. |
Ok, I had not detailed look at this part. Now a few questions arise, as usual |
Sorry you are correct, if you remove the cable you won't be able to lock or possibly open the tailgate.
