![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Ok, that's clear, thanks a lot for supporting a newbie mechanic |
Its on top of the air suspension strut, looks like the +ve jump stud but any bolt will do. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
When you get to the bottom of this - if you ever do - please let me know. Mine has gone for two weeks parked at airports and started no problem. Today two days on the drive and although it turned over (just) it wouldn't start, the C-Tek is connected and it'll be fine in 20 minutes. It's a new battery (big Bosch as recommended by others) and the only difference from the old one is it will support whatever the drain is, run the FBH for 10 mins and start the car after being left for 1 night.
Ok, I sure will (get this fixed & tell here |
I found interesting bits here http://www.rangerovers.net/rrmkiiiremedies.html#batdrain 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Ok so I got the car back and did the tests:
Flat battery again tonight.
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Ibartsimp,
Thanks for the in depth reply. Indeed, I admit that the 0 reading on the ohmmeter is not normal.
Procedure for testing for current drain from circuits.
Guys, thanks for your support !
UPDATE : I now have correctly wired the ohmmeter (from the -ve terminal to the -ve wire) and now I read the tension going down. from 5 to now around 4, waiting for all systems to go down
now reads 0.01, meaning I have no drain?
