Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 |
Thx, how are the ground points identified?
14th Jan 2013 7:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Earth points: all brown wires, usually many together at these points:
15th Jan 2013 3:55pm |
Hi Joe, thx for the info. I'll check that. Reg the FSR, the only, maybe apparent symptom is battery drain.
15th Jan 2013 6:36pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
When my FSR went it was so hot after the car was parked for 4 hours it burned my technician, surprised the car didnt catch fire. One day your life will flash before your eyes......................................make sure yours is worth watching!
15th Jan 2013 6:42pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
A way to test an FSR is to install an ammeter in the battery earth cable and measure the current drain after the car has gone to sleep and then do the same again having removed fuses 34 and 64.
15th Jan 2013 7:04pm |
Thanks a lot for the info, I'll pass it to the garage (just in case) |
16th Jan 2013 8:07am |
Here's the update : got my car back today, and guess what, everything is ok (and has been for the full week). The test bookd didn't give anything
18th Jan 2013 2:39pm |
Flat battery again this morning grrr |
19th Jan 2013 9:54am |
tested it, 11.2v, does it mean it's definitely dead? or just that it needs to be recharged?
19th Jan 2013 11:04am |
No it's not dead just needs recharged.
19th Jan 2013 11:28am |
Ok, battery charged, battery is delivering only 14v whatever the rpms (2000, 3000), measured at the positive & negative battery terminations.
20th Jan 2013 3:04pm |
From battery earth to what please? |
20th Jan 2013 3:11pm |
If the battery is fully charged then thats about the same as mine. One day your life will flash before your eyes......................................make sure yours is worth watching!
20th Jan 2013 3:12pm |
ok, thx
21st Jan 2013 8:46am |
