Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 |
Ok, that's clear, thanks a lot for supporting a newbie mechanic
21st Jan 2013 9:15am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
Its on top of the air suspension strut, looks like the +ve jump stud but any bolt will do. |
21st Jan 2013 9:28am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3778 |
When you get to the bottom of this - if you ever do - please let me know. Mine has gone for two weeks parked at airports and started no problem. Today two days on the drive and although it turned over (just) it wouldn't start, the C-Tek is connected and it'll be fine in 20 minutes. It's a new battery (big Bosch as recommended by others) and the only difference from the old one is it will support whatever the drain is, run the FBH for 10 mins and start the car after being left for 1 night.
21st Jan 2013 11:22am |
Ok, I sure will (get this fixed & tell here )
21st Jan 2013 6:02pm |
I found interesting bits here http://www.rangerovers.net/rrmkiiiremedies.html#batdrain 2008 TDV8 VOGUE - Buckingham Blue on Sand |
21st Jan 2013 9:52pm |
Ok so I got the car back and did the tests:
25th Jan 2013 5:21pm |
Flat battery again tonight.
28th Jan 2013 6:20pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
Ibartsimp,
28th Jan 2013 6:49pm |
Thanks for the in depth reply. Indeed, I admit that the 0 reading on the ohmmeter is not normal.
29th Jan 2013 8:14am |
Procedure for testing for current drain from circuits.
29th Jan 2013 9:19am |
Guys, thanks for your support !
29th Jan 2013 4:15pm |
UPDATE : I now have correctly wired the ohmmeter (from the -ve terminal to the -ve wire) and now I read the tension going down. from 5 to now around 4, waiting for all systems to go down
29th Jan 2013 5:45pm |
29th Jan 2013 5:47pm |
now reads 0.01, meaning I have no drain?
29th Jan 2013 6:08pm |
