Home > Technical (L322) > 4.4 tdv8 started smoking.
Page 2 of 8 <12345678>
kevinp
Thanks for the info Andrew.
Other hands only touch my car if absolutely necessary. Rolling with laughter
My local Indie is Roean in Telford and have done Warranty work but it's also nice to hear of praise for another local Indie. Their Website sounds as if they are a caring outfit.
Post #659900 20th Mar 2023 5:09pm
Rusty Nuts
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hi Kevin ,
I know that you mean about doing as much yourself. Same here .
Roger is very approachable and knowledgeable.
Andrew.
Post #659916 20th Mar 2023 7:20pm
DrRob
From a fair bit of reliable feedback I would go to Clarkes all day long. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #659928 20th Mar 2023 9:02pm
Glad you seem to have gotten to the bottom of your issues KevinP... These things can be very unnerving can't they... Neutral
Post #659942 21st Mar 2023 1:14am
kevinp
Thanks Craig. It was very unnerving at the time as it had never done it before.
To be honest I still can't fathom out why it did it because the second turbo gets used at least a couple of times a week.
With your expertise is there anything you would check?
Thanks Kev.
Post #659951 21st Mar 2023 8:26am
kevinp
Well it's got a lot worse even to the point of smoke still coming out the exhausts when stationary if I've revved it past 2500rpm.
It's going to Clarkes tomorrow for their opinion. Censored Big Cry
Post #663760 10th May 2023 3:41pm
DrRob
Keep us posted 👌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663787 10th May 2023 7:18pm
kevinp
Never had to top up oil before, just checked the level before I go to Clarkes and I've had to put 3 litres in!!
Not looking good. Big Cry
Post #663847 11th May 2023 1:08pm
DrRob
That's a lot of oil to lose.
I hope it's an easy fix Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663856 11th May 2023 2:35pm
kevinp
No Rob. Needs new turbo's. £6500. Engine out job.
Thanks Andrew for suggesting Clarkes.
It's going back to them next Monday for them to look if it's had the turbo drain mod and rule anything else out but the amount of oil it has used and the amount of smoke it gave out on the test drive we can't see it being anything else. Censored
Post #663858 11th May 2023 2:55pm
JayGee
Vey unlucky to have the turbo's let go on these although it's the 2nd time this month -
What's the mileage and service history? Main reason for turbo failure is oil starvation. 2012 TDV8 Vogue (L322)
Post #663859 11th May 2023 3:05pm
pcourtney
I check my oil every week, but it is a pain to open the bonnet and then get back in the car just to enter the service menu on the TFT screen and see if all is well Smile
there must be a good reason why they do that ?
just tried doing it from cold, and it works - wow - did not know that - thx Rob
also, does an Oil Light come on by chance if I am very low on oil ?? ( 2011 TDV8 car )
Post #663863 11th May 2023 3:37pm
DrRob
No need to open bonnet. Check it cold in morning. Should be one or two notches above mid line. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663864 11th May 2023 3:47pm
kevinp
The last time I drove it there was no low oil warning!! I would have expected one giving the amount I had to put in.
My car has a fully stamped service book and I must say I am very disheartened at the moment. I have just finished replacing all the wear and tear items, which have cost thousands and now this. Censored Big Cry
Post #663866 11th May 2023 3:50pm
DrRob
You can put reconditioned turbos on instead of new Genuine if that’s what they’re quoting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663867 11th May 2023 3:51pm
