Home > Technical (L322) > 4.4 tdv8 started smoking.
Page 3 of 8 <12345678>
Rusty Nuts
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Sorry to hear the news Kevin. Not good.
It’s odd you didn’t get an oil light warning as you say.
Post #663869 11th May 2023 3:59pm
kevinp
DrRob wrote:
You can put reconditioned turbos on instead of new Genuine if that’s what they’re quoting
Clarkes have had bad luck with recon turbo's Rob and because it is such a big job they only recommend using genuine new ones.
Post #663870 11th May 2023 4:24pm
kevinp
Thanks Rusty Nuts.
Post #663871 11th May 2023 4:25pm
JayGee
pcourtney wrote:
also, does an Oil Light come on by chance if I am very low on oil ?? ( 2011 TDV8 car )
Low oil would give a low oil pressure warning in some circumstances but AFAIK the oil level has to be checked and there is no actual low level warning. 2012 TDV8 Vogue (L322)
Post #663872 11th May 2023 4:37pm
DrRob
What was the root cause though? When was the oil last changed? Did the garage not put the correct amount in? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663881 11th May 2023 5:50pm
kevinp
I do all my own oil changes every 3-4000 miles with a genuine filter and up to now used Shell helix.
It couldn't be that I've just put in some Smith and Allen oil 1000 miles ago, surely not!
Everybody panic!!!
Post #663883 11th May 2023 6:13pm
JayGee
The wrong oil wouldn't damage a turbo unless it was in there for a very extended period of time. The root cause probably won't be known until the turbo's are out and torn down and the damage may have been done long before you had it. 2012 TDV8 Vogue (L322)
Post #663884 11th May 2023 6:24pm
kevinp
Thing is Jaygee it has never smoked at all, just the last few weeks. And like I've said it has never used a drop of oil between changes.
Post #663895 11th May 2023 7:55pm
JayGee
"Today I had a sound similar to a stone being rattled in a tin can and then a puff of smoke from the exhaust." - just read this from the start of the thread. This sounds also like something could have got ingested into the turbo from the intake side. 2012 TDV8 Vogue (L322)
Post #663897 11th May 2023 8:13pm
Merchy
Sorry to hear the bad news Kev, not good especially after seeing your car and the superb condition you keep the car in. Sounds like everything was ok and then the turbo threw it's hand in. As for the above post, it 'may' have ingested something. In my work when turbochargers fail it's with little or no warning, because of the high speed once the bearing starts to go things happen quickly.
At least you already have a garage where they know what they are doing, we 'recon' turbo's, but it's a different ball game due to the sizes and number of parts involved.
Hope all goes well
Rob
Post #663908 11th May 2023 9:45pm
kevinp
Thanks Rob. Obviously I won't drive it till it's fixed because I'm worried it could block the DPF. On the test run it still goes like Joe Stink with no noises but more like Joe Smoke now!
Post #663913 12th May 2023 6:21am
DrRob
Keep us posted and fingers crossed it all works out and you get the motor back in fine fettle...despite the ding to the wallet Big Cry
You'll have to keep it now for a long time - which is no bad thing Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663914 12th May 2023 7:33am
kevinp
Will do Rob. It's a keeper. It's my caravan tug and was planned to be my last car anyway. Thumbs Up
Post #663925 12th May 2023 9:12am
kevinp
Just had a quote from my local MD.
£9,720. Rolling with laughter
Post #663941 12th May 2023 12:50pm
GraemeS
Australia
If the turbo spindle is now out of balance having taken a hit or lost parts of vanes then the seals will likely leak oil even if the seals haven't been damaged.
Post #663947 12th May 2023 1:47pm
