![]() | Home > Technical (L322) > 4.4 tdv8 started smoking. |
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 54 ![]() ![]() ![]() |
Hi Kevin ,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 ![]() ![]() ![]() |
From a fair bit of reliable feedback I would go to Clarkes all day long. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 ![]() ![]() ![]() |
Glad you seem to have gotten to the bottom of your issues KevinP... These things can be very unnerving can't they... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1214 ![]() ![]() ![]() |
Thanks Craig. It was very unnerving at the time as it had never done it before.
Well it's got a lot worse even to the point of smoke still coming out the exhausts when stationary if I've revved it past 2500rpm.
Keep us posted 👌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Never had to top up oil before, just checked the level before I go to Clarkes and I've had to put 3 litres in!!
That's a lot of oil to lose.
No Rob. Needs new turbo's. £6500. Engine out job.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3229 ![]() ![]() ![]() |
Vey unlucky to have the turbo's let go on these although it's the 2nd time this month -
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 ![]() ![]() ![]() |
I check my oil every week, but it is a pain to open the bonnet and then get back in the car just to enter the service menu on the TFT screen and see if all is well |
No need to open bonnet. Check it cold in morning. Should be one or two notches above mid line. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The last time I drove it there was no low oil warning!! I would have expected one giving the amount I had to put in.
You can put reconditioned turbos on instead of new Genuine if that’s what they’re quoting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
