![]() | Home > Technical (L322) > 4.4 tdv8 started smoking. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1237 ![]() ![]() ![]() |
Glad to hear the good news Kev |
That sounds like good news but how do you explain loosing 3L of oil. I'd remain cautious but optimistic |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4335 ![]() ![]() ![]() |
Roger to the rescue! Family use Clarkes and are very impressed with their service and knowledge! (Less so for Roean btw!)
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
Roean says there isn't a turbo drain mod, they even rang Land Rover Direct who also told them there isn't one!!!! We know more than the so called experts mate. |
There you go! Has yours had it fitted out of curiosity? Roger will know 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
He couldn't tell me unfortunately. I thought he would. He says there is newish sealant around the lower core plug though.
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 61 ![]() ![]() ![]() |
Glad to hear you are making progress with the problem Kevin.
Update, the car is still going okay. There is still a puff of smoke when the second turbo hasn't been used in a while but no smoke if used again over the next few miles/days.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Green Oval is a great company and know their stuff with this mod, they did mine and it completely resolved the issue. Mine resembled a James Bond movie when overtaking etc if it hadnt stretched it's legs for a few miles, absolutely horrendous. BMW i3 Electric Car
Save yourself a load of cash and risk with the turbo drain mod by simply booting it above 2500rpm regularly when warm |
Until it dumps enough oil in there for diesel runaway and then youre royally screwed. BMW i3 Electric Car
It's never going to cause a runaway as it's not dumping oil in the intake side. Mine smoked very badly when I first had it but I only get a mild puff now and again when I use the 2nd turbo. Seems to be worse in summer as I've gone a few months in the winter without using the 2nd turbo and not seen smoke. 2012 TDV8 Vogue (L322) |
Thanks for the replies. Just changed the oil again after draining the mini sump. Made sure the engine was nice and warm and no smoke at the moment.
Result |
