Home > Technical (L322) > 4.4 tdv8 started smoking. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
What colour is the smoke? 2012 TDV8 Vogue (L322) |
19th Mar 2023 4:19pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1228 |
Blue/black. More blue I would say. |
19th Mar 2023 6:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8308 |
That's not good, it's not diesel (white smoke) it's engine oil...
19th Mar 2023 7:26pm |
Yep, blue smoke is engine oil - the 'rattle' will have been uncontrolled combustion - AKA diesel knock
19th Mar 2023 7:58pm |
Thanks guys. When I've looked in the hoses in the past I would say they are definitely wet rather than just misted.
19th Mar 2023 8:32pm |
It could well turn into a 'runaway' have you checked the oil level? If you have a DPF and there is excessive oil dilution it's possible the excess oil/fuel is making it's way into the induction tract, which, of course, is 'uncontrolled'.
19th Mar 2023 8:47pm |
Blue smoke is oil being burnt / combusted in the cylinders so it’s getting there from the induction side - not good. White smoke is oil just vaporising in the exhaust from the turbo exhaust seals I.e ‘drain mod smoke’. Get the turbo’s checked as there shouldn’t be enough oil getting past the seals in normal operation to cause visible smoke 2012 TDV8 Vogue (L322) |
19th Mar 2023 9:23pm |
All good advice, Thankyou.
19th Mar 2023 11:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2513 |
It shouldn't be possible to have a runaway due to oil from the secondary turbo if the ignition has been switched off because the inlet isolation valve is closed with the ignition off, thereby closing off the gross supply of oil.
20th Mar 2023 1:31am |
It’s not been neglected with 3k Mile oil changes ! With the turbo outlet hoses off wiggle the turbo shafts to check for excessive play. There will be some as it’s a floating shaft / bearing. 2012 TDV8 Vogue (L322) |
20th Mar 2023 8:31am |
Thankyou both. I will go and have a poke about. |
20th Mar 2023 9:39am |
Well I decided to treat it to an 'Italian tune-up' as recommended by folks on here.
20th Mar 2023 12:51pm |
Good news, just "drive it like you stole it" everywhere, and all is well...........
20th Mar 2023 1:26pm |
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 56 |
Hi Kevin.
20th Mar 2023 1:55pm |
