Home > General > What Did You Do In Your Full Fat Today
Page 262 of 382 <123 ... 261262263 ... 380381382>
Weegie
Move the mirror selector button on the driver door panel to nearside mirror door adjustment. It's a feature to aid parking at the kerb. You can select it using the button. John
GAP iiD BT-Sold
Post #457536 16th Nov 2017 7:10pm
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
Fit the secondary battery today, Hopefully no more flat batteries for quite a while, although I'm 320 euros worse off now.
Post #457539 16th Nov 2017 7:33pm
AJ Johnny
Collected my new-to-me ff from the indy following a rad blow. One new rad and hoses, spare key, battery, balance hose, gas plugs, alternator, bonnect release handle, four discs, all oils, all filters and full service later I am considerably poorer but happy 😀
Now to save up for a gas kit.
At least I know it won’t break down now. No. Surely not. It won’t, will it?
Will it??
Post #457540 16th Nov 2017 7:54pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Changed the o/s rear cv joint and gaiter due to the boot being split and failing the mot.
And made a start on replacing the rear brake lines thanks to joe90’s how to just can’t get an Allen key to fit the cover on the n/s to expose the lines. May have to snap them off some how!
Post #457738 18th Nov 2017 5:07pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Took a bunch of stuff to the office, filled her up at the Shell garage on the way home and procrastinated about whacking a load of hide feed into the interior. I'll probably do that tomorrow.
Post #457755 18th Nov 2017 7:24pm
AJ Johnny
Did three trips totalling fifty miles with no messages or failures. Loved it! Then a side light failed. Oh well, fault free driving is getting closer.
Is that what FFRR stands for - Fault Free Range Rover?
Post #457765 18th Nov 2017 7:58pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
The Duchess
Just had a busy week for the Duchess
135,000 miles
MOT passed
Fully service including gearbox flush, transfer box and diffs done
New (to me) 20" Westminster alloys and winter tyres
Broke but happy 😎 2009 Stornoway Grey Vogue TDV8
Post #457772 18th Nov 2017 9:27pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Gave it a wash and a coat of wax, the bonnet and roof really need going over with the DA polisher but didn’t have time today as the wife’s Disco needed a wash.
Also discovered the puddle lights on the mirrors don’t work Sad gives me something to do I suppose
Post #457854 19th Nov 2017 5:58pm
AJ Johnny
Tried the heated steering wheel, first time for me, excellent! Switched on the heated seat which momentarily stopped the hvac before the seat heater switched off after 1 second and the hvac then recovered. Tried again with repeatable result. Has it anything to do with having the hvac wiring harness mod last week? Trapped wire or a tap into the wrong circuit? Hmmm...
Post #457896 20th Nov 2017 12:33am
Hitby
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Washed it, clayed it, machine polished it and waxed it. It took 5 hours with a friend helping me. Quite an improvement - it looks like we polished the blue out of it Whistle
Post #457904 20th Nov 2017 10:08am
AJ Johnny
Called into the indie, it is the harness causing the seat heater trouble. Driver seat heater on causes repair harness relay to change over and kills feed to a/c head unit, then relay re-energises. Remove the relay and seat heater works but battery will drain. He’s calling tech for an opinion.
Post #457942 20th Nov 2017 3:21pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
Fitted a Mantec exhaust guard.... only need centre and front one now!!
 "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #457947 20th Nov 2017 3:46pm
RRV78
Replaced both rear brake pipes as failed the mot. Retest tomorrow!
Post #457958 20th Nov 2017 5:16pm
Paulus1978
Took her for our first long drive together. A 258 mile round trip to the north bank of the Thames Estuary and back for work.
The weather was pretty dire as we set out at 05:15 this morning, and none too warm, so i had the heated steering wheel and seats on for a few minutes. The traffic was backing up a little down the M1, so we didn't make very good progress, and I was a little put out that we couldn't stay on the Cruise Control for very much of the drive down. Parking her up at the other end, I felt sad at how dirty she now looked, with streaks of dried road water down her flanks and bonnet, the tailgate was pretty terrible too. The headlights had done a good job of piercing the dark and dismal morning, so at least I arrived knowing what had been in front of me.
I finished the visit earlier than anticipated, and I found myself back on the M25 driving north in dry but cloudy times. The drizzle came and went, but at least the road was clearer and we were able to stick the CC on at 60 and purr home. Classic FM on in the background, and the reassuring thrum of her 3.6 V8, I found myself talking to the car. Thanking her for the traffic updates from the Sat Nav, and encouraging her with a gentle "there we go sweetheart, time to go" when we pulled out from behind a slow lorry and i hit "Resume" on the steering wheel.
I'm not sure how, but I've ended up giving her a name (I've never named ANY of my cars before), and feeling like as long as she has good maintenance and gentle attention, she won't let me down. Did Land Rover build these cars with a soul?
Post #457967 20th Nov 2017 6:21pm
Weegie
After a previous abortive attempt got a FFRR sticker in place. Wink John
GAP iiD BT-Sold
Post #458067 21st Nov 2017 2:10pm
