Home > General > What Did You Do In Your Full Fat Today
Page 382 of 382 <123 ... 380381382
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Clicked over 100,000 miles today in my MY2012 - 40,000 of which are mine and I’ve enjoyed every one of them.
Post #716110 14th Apr 2025 8:25pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Had the underneath totally cleaned, heat shields etc removed, any surface rust converted with Fertan and then when that had dried, all exposed surfaces were sprayed with Dynax UC, cavities, inside of subframes etc liberally sprayed with Dynax S50.
Post #716150 15th Apr 2025 2:54pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I had my oil leak sorted along with a few other issues. My leak was the oil cooler so it was replaced. The coolant reservoir was flushed but for some reason the float wouldn't do what it was born to do. I wasn't going to live with a constant low coolant warning so I asked the garage to just change it too.
My headlight washers were not working,turned out the high pressure squirty pump also decided to cease doing its job. Same with the rear window washer pump.
The garage also spotted worn upper suspension bushes at the back and so they were changed out.
Refill of coolant and fresh oil and filter and good to go.
I have also had to order up a passenger side rear knuckle. Found one by NTY on eBay for £125. It appears genuine LR part is rare / possibly extinct and around £600 if you find stock.
Post #716177 15th Apr 2025 10:55pm
