Home > General > What Did You Do In Your Full Fat Today |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Move the mirror selector button on the driver door panel to nearside mirror door adjustment. It's a feature to aid parking at the kerb. You can select it using the button. John
16th Nov 2017 6:10pm |
nar53 Member Since: 04 Nov 2015 Location: Le Mans Posts: 120 |
Fit the secondary battery today, Hopefully no more flat batteries for quite a while, although I'm 320 euros worse off now.
16th Nov 2017 6:33pm |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
Changed the o/s rear cv joint and gaiter due to the boot being split and failing the mot.
18th Nov 2017 4:07pm |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 |
Took a bunch of stuff to the office, filled her up at the Shell garage on the way home and procrastinated about whacking a load of hide feed into the interior. I'll probably do that tomorrow. |
18th Nov 2017 6:24pm |
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 77 |
Did three trips totalling fifty miles with no messages or failures. Loved it! Then a side light failed. Oh well, fault free driving is getting closer.
18th Nov 2017 6:58pm |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 |
Just had a busy week for the Duchess
18th Nov 2017 8:27pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
Gave it a wash and a coat of wax, the bonnet and roof really need going over with the DA polisher but didn’t have time today as the wife’s Disco needed a wash.
19th Nov 2017 4:58pm |
Tried the heated steering wheel, first time for me, excellent! Switched on the heated seat which momentarily stopped the hvac before the seat heater switched off after 1 second and the hvac then recovered. Tried again with repeatable result. Has it anything to do with having the hvac wiring harness mod last week? Trapped wire or a tap into the wrong circuit? Hmmm... |
19th Nov 2017 11:33pm |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 |
Washed it, clayed it, machine polished it and waxed it. It took 5 hours with a friend helping me. Quite an improvement - it looks like we polished the blue out of it
20th Nov 2017 9:08am |
Called into the indie, it is the harness causing the seat heater trouble. Driver seat heater on causes repair harness relay to change over and kills feed to a/c head unit, then relay re-energises. Remove the relay and seat heater works but battery will drain. He’s calling tech for an opinion. |
20th Nov 2017 2:21pm |
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 |
Fitted a Mantec exhaust guard.... only need centre and front one now!!
20th Nov 2017 2:46pm |
Replaced both rear brake pipes as failed the mot. Retest tomorrow! |
20th Nov 2017 4:16pm |
Took her for our first long drive together. A 258 mile round trip to the north bank of the Thames Estuary and back for work.
20th Nov 2017 5:21pm |
After a previous abortive attempt got a FFRR sticker in place. John
21st Nov 2017 1:10pm |
