Home > Technical (L322) > Where did that cloud of smoke come from?
Page 7 of 13 <123 ... 678 ... 111213>
DrRob
Please can you summarise your symptoms and fixes to save me trawling Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588769 24th Mar 2021 8:31pm
Range Rover L322
DenniJ - you need to speak to Dolphinboy. I'll send him this thread.
Post #588807 24th Mar 2021 11:29pm
Dolphinboy
Symptoms were originally:
1. several incidents of RP at the same spot on the M4. Then after a year started getting DPF yellow warning followed by a red after a while. I fixed that myself somehow with my IID tool. No warning codes. Car ran fine other than repeated DPF warnings and RP. Went to red and got the DPF cleaned and reset for £200 by franchise (terraclean).
2. Had the inlet manifold changed and car ran fine for a while but then I got a yellow again and RP. IID tool showed lots of incomplete regens (in their 000's) at a time.
3. Steve found broken Thermostat housing (probably when another garage fitted the inlet manifold). cause of DPF incomplete was low engine temps. he managed to get it to regen of its own accord by taking it up steep hills in low gear at speed! Changed thermo, housing and engine temps sensor and now all good. Thumbs Up
here are my posts on it.
https://www.fullfatrr.com/forum/topic55878.html
Post #588808 24th Mar 2021 11:29pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
@RangeRover L322 I have been in contact with dolphinboy on a few occasions regarding this (see thread comments) hence why I was looking at coolant temperature and voltage, nothing conclusive for me so far but I haven’t ruled it out yet. After the last red warning popped up in December I parked the car up and just gave up on it as I had reached the end of my patience at that point, probably something to do with the vast sums already being spent and feeling like I hadn’t had any progress. Now that spring has arrived I have set myself the task of trying to get to the bottom of this once and for all, I need to sit down and collate all the information I have so far and carry on working through the troubleshooting as shown in the WM (I have carried out quite a bit of that so far). As I haven’t had anything new to report I haven’t updated this thread for a while but felt some hope when I saw Dr Rob post of a similar, if not identical issue. Hopefully, as a collective we can get the issue resolved as sometimes a fresh pair of eyes can spot something that someone else has missed or become blind too. 2011 TDV8 Vogue SE
Post #588824 25th Mar 2021 9:22am
DrRob
He started this thread Thumbs Up Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588834 25th Mar 2021 10:04am
DrRob
Post #588835 25th Mar 2021 10:07am
dennij
That’s quite a bit of oil residue there, bloody annoying that you can’t just buy a new seal. For what it’s worth I purchased a new one and fitted but it made no difference, however, I didn’t have that much oil residue on my old one 2011 TDV8 Vogue SE
Post #588837 25th Mar 2021 10:29am
DrRob
Agreed. Crap design. Next step is smoke test
They got the diff press sensor to hit 1V by revving to 4000rpm static as per WM. It then dropped back to 0.7V.
Fans also kicking in way too early so we also suspect thermostat and/or ETC sensor as per dolphinboy had
Local indy reckons it could be a DPF sensor - I wonder if he means temp / pressure sensor? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588839 25th Mar 2021 10:38am
DrRob
PS What are people's real names ? Easier than writing out handles all the time!!
Mine is...errr....Rob
Dolphinboy = James
dennij = John
RangeRoverL322 = Matt Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588841 25th Mar 2021 10:59am
dennij
Dennij = John Thumbs Up 2011 TDV8 Vogue SE
Post #588846 25th Mar 2021 11:24am
dennij
If you need the pressure sensor part number let me know as my DPF is currently off the car so I can post a picture if required 2011 TDV8 Vogue SE
Post #588847 25th Mar 2021 11:25am
Dolphinboy
Dolphinboy ???
dennij???
dolphinboy - James
Post #588862 25th Mar 2021 1:49pm
DrRob
Might as well. Keep your reports coming too! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588866 25th Mar 2021 2:27pm
DrRob
Look forward to an update soon Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588868 25th Mar 2021 2:29pm
kevinp
I had a new pipe under warranty mate. If it cheers you up Rob, my pipe was, perhaps still is, soaking wet inside. My Indie says it's not unusual. The only source it can come from is the turbo unless someone knows any different.
Post #588880 25th Mar 2021 3:38pm
