![]() | Home > Technical (L322) > Where did that cloud of smoke come from? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
H Dolphinboy I have a new coolant sensor on order as this was my next port of call going on your earlier recommendation. I will have a good look at the wiring whilst replacing and see what I find. On a positive note I did manage to fix the windscreen wiper, it had popped off the assembly arm and just needed to be clipped back in place 2011 TDV8 Vogue SE |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3220 ![]() ![]() ![]() |
Dennis, am thinking at all the long shots now. Take them with a pinch of salt.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
What's this reading? Ideally under driving conditions, not heavy throttle ? Also at idle ? If at idle it's 0.7 to 0.8 v that's normal. Under load should be around 1.0v Otherwise: For some reason the regeneration didn't like the conditions. So worth just checking the basics: -Were you using cruise control? Regens much prefer cruise -Did your fuel fall below 1/4 tank while regenning? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Hi Dolphinboy, any options are currently considered so any pointers are always appreciated |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Let’s work together on this. Family friends 2011 4.4 tdv8
Sounds like a plan to me, happy to provide any input I can from my own tests carried out so far. 2011 TDV8 Vogue SE |
This is the current state of my DPF, sadly you cannot see the rear end due to the design which is probably where most of the ash blockage would be. To be honest I was surprised it looked as clean as this as my reading is now in the red, although you can see a thick deposit at the lower edge.
Did he (Steve Norman?) change the entire thermostat housing or just the engine coolant temperature sensor (ECT) on the front of the housing?? Is there more than one sensor as you use the plural "sensors"? ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Why have you got EGT in Volts and not Temperature? Temperature is the normal field we choose I thought? ![]() ECT Sensor in Volts = is this a normal figure (0.357) at 92 'C? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Normally I have temps
@dr Rob.
OK, thanks. Is yours now running ok Dolphinboy? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Yep Rob. Faultless. Steve just said he worked down through all the possible options until he hit the one that made the difference. |
