Home > Maintenance & Mods (L322) > Plastic sill removal. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Post a picture of your modified trim before you fit it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Apr 2020 7:45am |
Dynax wax sprayed inside both sills via holes underneath. You can see it dripping out of the lower joint where there are small holes in the seam joints. Taped the vertical holes where the covers clips into with masking tape to avoid spray out! 1 tin did both sides.
24th Apr 2020 9:39am |
Not Scrivets. Plastic rivets are different ANR2224 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
24th Apr 2020 2:37pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 212 |
Part number for the 2 scrivits that are at the rear into the wheel arch liner is DYQ100230. |
24th Apr 2020 5:58pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
https://www.comdir.co.uk/scrivets-flush-head-type.html John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
24th Apr 2020 6:05pm |
I like them. Better than the original prise out ones They come in 8mm too Cheers Weegie Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
24th Apr 2020 8:03pm |
25th Apr 2020 7:43am |
All done. I prefer the Freelander 2 trims cut to fit. They cover the lip a fraction more and also look more OEM. I couldn't get them to "join" the trailing edge ones due to the lip issue. I've smeared the small 2" area of exposed lip with clear waxoyl.
26th Apr 2020 6:51am |
sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36 |
I managed to treat both sides over the weekend. Thankfully not much rust, only some light surface patches. I treated with Kurust and then followed Matt's video with Hammerite and Waxoyl.
27th Apr 2020 9:44pm |
Kev - any luck with a picture of your mod? I'm intrigued Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
28th Apr 2020 7:37am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Forgot to mention this earlier, but, when I cleaned my sills last week with the plastic trim off, I saw evidence of some sort of wax dribbling out of one of the grommets [same as in one of Dr Robs photo's] can one assume then that JLR treated the inner sills with waxoyl or similar from new?
28th Apr 2020 7:54am |
Yes, they would have been treated at the factory. I’ve just topped it up
28th Apr 2020 8:16am |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 |
Hi All!
28th Apr 2020 1:35pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 317 |
Nice looking Supercharged Rangie! ---------------------------------------
28th Apr 2020 2:04pm |
