![]() | Home > Maintenance & Mods (L322) > Plastic sill removal. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
The foam blocks appear to fill a void between the end of the sill and the end of the plastic sill cover and stop muck accumulating. Maybe only later ones had them fitted. Not sure |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Why thank you sir! |
Weren't any on mine and that's a 2006. Si. |
nfm Member Since: 09 Apr 2019 Location: UK Posts: 20 ![]() ![]() |
Thanks, sounds like maybe mine didn’t have them then; certainly the sill covers didn’t look like they had been off before. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
Ay up Rob. I will try and post some photos mate. Things didn't quite work out! I ordered 1 meter of the seal for each side thinking there would be plenty to do the kink. 1 meter is only just long enough to cover the whole arch without cutting for the kink!!!! It does look nice though fitted and virtually covers all the metal lip. Search Amazon,' TMH large u section 21mm x 8mm.' |
Freelander 2 trims fitted on leading edge of rear wheel arch
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Not the best of photo's to be honest, but shows the door open then closed & using standard non Freelander 2 trims.
That small gap is why I swapped to FL2 trims but I’m an OCD c u next Tuesday |
My phone camera is a bit crap but you might be able to see what iv'e done. My first attempt to send a picture!!
Nice. Got a picture of the kinky bit in situ on the car? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Ingenious |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
What are people using to "fill" the trims before fitting. I did mine last year and filled them with grease but when I had a sneaky look today the grease has gone. Is there a "solid" version of waxoyl type product that could be used. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
I used Bilthamber wax for my tailgate. Injected using the "straw" provided. They have a number of products. Better than grease IMHO.
