Home > Maintenance & Mods (L322) > Plastic sill removal.
Page 5 of 7 <1234567>
DrRob
Post a picture of your modified trim before you fit it Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551541 24th Apr 2020 7:45am
DrRob
Dynax wax sprayed inside both sills via holes underneath. You can see it dripping out of the lower joint where there are small holes in the seam joints. Taped the vertical holes where the covers clips into with masking tape to avoid spray out! 1 tin did both sides.
Next, brush clear waxoyl on both ends of each sills and along bottom and inside edges, replace foam blocks, plastic covers and fit arch lip protectors. Will try the Freelander 2 ones and compare to the others I fitted like NFDI and Fox889. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551555 24th Apr 2020 9:39am
DrRob
Weegie wrote:
BMG wrote:
the lower two piece clips ( the ones where you are inserting a pin to expand ) .
Scrivets. Thumbs Up
Not Scrivets. Plastic rivets are different ANR2224 Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551573 24th Apr 2020 2:37pm
PeteT80
Part number for the 2 scrivits that are at the rear into the wheel arch liner is DYQ100230.
Post #551594 24th Apr 2020 5:58pm
Weegie
DrRob wrote:
Weegie wrote:
Scrivets. Thumbs Up
https://www.comdir.co.uk/scrivets-flush-head-type.html Question John
GAP iiD BT
Post #551597 24th Apr 2020 6:05pm
kevinp
Me and technology don't go together mate. I'll ask my daughter to post a picture in a bit. Neutral
Post #551601 24th Apr 2020 6:41pm
DrRob
Weegie wrote:
DrRob wrote:
Weegie wrote:
Scrivets. Thumbs Up
I like them. Better than the original prise out ones Thumbs Up
They come in 8mm too Bow down
Cheers Weegie Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551606 24th Apr 2020 8:03pm
DrRob
Shocked Big Cry
Get yours checked and waxed inside! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551619 25th Apr 2020 7:43am
DrRob
All done. I prefer the Freelander 2 trims cut to fit. They cover the lip a fraction more and also look more OEM. I couldn't get them to "join" the trailing edge ones due to the lip issue. I've smeared the small 2" area of exposed lip with clear waxoyl.
The new underside clips (ANR2224) were a Censored swine to get in. Split them into 2 obviously to start with then tap in with a small hammer and wide drift but be careful not to hit too hard and break them! Whistle Big Cry
I'd be tempted to try the one Weegie mentioned above
8 x 22mm I think the original ANR2224 spec are: https://www.advancedfactors.co.uk/anr2224-...2758-p.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551683 26th Apr 2020 6:51am
sumshiftyguy
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I managed to treat both sides over the weekend. Thankfully not much rust, only some light surface patches. I treated with Kurust and then followed Matt's video with Hammerite and Waxoyl.
I had ordered some Dynax for the sill cavities but annoyingly it hadn't arrived in time and I wanted to get the job done before the rain this week. It's arrived today so will save that for another day!
I've also ordered a second set of the Freelander rubbers as I'm going to replace the original parts on the leading edge of the arch. The fit looks good and the originals look tired. I'm hoping this will also allow me to match up in the middle more cleanly.
I did have an interesting time with one of the wheel nuts though!
Post #551883 27th Apr 2020 9:44pm
DrRob
Kev - any luck with a picture of your mod? I'm intrigued Whistle Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551904 28th Apr 2020 7:37am
Fox889
Forgot to mention this earlier, but, when I cleaned my sills last week with the plastic trim off, I saw evidence of some sort of wax dribbling out of one of the grommets [same as in one of Dr Robs photo's] can one assume then that JLR treated the inner sills with waxoyl or similar from new?
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #551909 28th Apr 2020 7:54am
DrRob
Yes, they would have been treated at the factory. I’ve just topped it up Thumbs Up
Fanders images also show “factory dribble” Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #551910 28th Apr 2020 8:16am
Anvil
Isn't it funny how one thing leads to another......
Hi All!
Went out to put some replacement clips in a set of mud guards I fitted the other day. Then I remembered this thread, and that I'd already painted and wax injected the sills at the rear wheel arches. Soooo..... I stipped off the plastics to reveal watermarked but factory fresh sills.
So I cleaned them up,
And gave them a totally unnecessary coat of smoothrite.
Then wax injected them thoroughly.
The rest of the car was solid as a rock underneath with the tinyest bit of surface rust here and there:
So it got a clean and a full underseal anyway.
Under the engine bay and all through the transmission: Not an oil leak in sight!!!
So the only question now, is.....
No style bars:
Or style bars?
Oh, and I painted the Exhaust while I was at it.
All done before yesterday's rain came in....... Phew!
Its worth doing if you plan to keep hold of your car, -Looks like I've got a great one!
Si.
Post #551952 28th Apr 2020 1:35pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Nice looking Supercharged Rangie! ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #551958 28th Apr 2020 2:04pm
