Home > Maintenance & Mods (L322) > Plastic sill removal.
Page 2 of 7 <1234567>
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Wish I could just pay someone to do mine! Its a struggle to find the time to do this kind of thing. I've only got light surface rust on the front of the arch so I'm hoping its all just going to be preventative, but I really want to get it done before it gets any worse.
I did get a quote from a body shop but I don't think they would go anywhere near as far as is necessary. 2010 4.4 TDV8 Vogue SE
Post #550918 19th Apr 2020 7:38am
DrRob
Doing mine next week. Got a bag of spare clips from Advanced Factors, Fertran rust converter, chassis black paint, Dynax S50 for sill cavity, and traditional clear waxoyl (hand brush it) for other areas.
And I’ll be doing the Classic’s sills and rear cross member at same time
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #550922 19th Apr 2020 7:52am
DrRob
Jim - what wax did you use to coat the arch? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #550924 19th Apr 2020 8:00am
Fox889
jim4244: I think a lot of us are now contemplating looking/doing the rear arches & under the inner shroud, had a look at my arch & there is slight surface rust there.
One question, you've jacked your rear up from under the rear hub rather than the 'BMW style' rectangular jacking point......any reason for this?
I have a new Sealey 2ton trolley jack ready for the job, but unbelievably, crap scared of jacking her up Embarassed 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #550925 19th Apr 2020 8:02am
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
I've just done mine on my 2003, previous owner had had the surface rust done in the door shut / arch and it was just showing through again.
When I took all the trim off, it was a right mess, my little hammer wend straight through the sil, passenger side was worse.
Had to do a fair bit of welding in the end. Don't be afraid to test it with a small hammer - the MOT man wont!
Post #550928 19th Apr 2020 8:20am
kooky_guy
I have to admit that Jack and axle stand location is one of my concerns. It was easy on my P38! 2010 4.4 TDV8 Vogue SE
Post #550929 19th Apr 2020 8:25am
stu1
Do you have the part number for the clips? Thumbs Up (I'm too lazy to go look it up Smile )
Post #550934 19th Apr 2020 9:10am
DrRob
Read the whole thread. There’s a link to the clips Thumbs Up Whistle Rolling Eyes Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #550954 19th Apr 2020 11:29am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Re jacking I tend to jack on either the chassis or the rear subframe.
I used a 3 ton jack to raise the car up and then lowered onto axle stands. I also alway always slide any wheel I have removed under the vehicle. In the photos I have 2 axle stands positioned, both wheels under the side beams of the chassis and a 2 ton and a 3 ton just touching the rear subframe as back ups.
Jim
Post #550958 19th Apr 2020 11:36am
jim4244
I used a couple of tins of this on the wheel arches.
This is used in the offshore oil & gas industry and came from a rig I was decommissioning. Not sure if it is any better or worse than many of the corrosion protectors out there?
What you probably can’t see is that after cleaning, applying rust converter and preparing the wheel arches I hand painted them with silver Hammerite Enamel. When this was dry I then over sprayed it with the SP400.
Jim
Post #550959 19th Apr 2020 11:41am
stu1
D'oh! Big Cry
Post #550960 19th Apr 2020 11:44am
DrRob
Hang on before ordering those clips until I’ve taken my covers off. I’m not convinced they are correct but will confirm soon Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #550963 19th Apr 2020 12:44pm
Weegie
BMG wrote:
the lower two piece clips ( the ones where you are inserting a pin to expand ) .
Scrivets. Thumbs Up
 John
GAP iiD BT
Post #550965 19th Apr 2020 1:03pm
DrRob
I think I now have the correct part numbers from a Facebook post that Matt Stevenson has done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #550970 19th Apr 2020 2:30pm
PeteT80
These are the correct fit for the plastic rivet type that run underneath.
https://www.ebay.co.uk/itm/190801217540
Post #550978 19th Apr 2020 4:47pm
