![]() | Home > Maintenance & Mods (L322) > Plastic sill removal. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Anvil - ditch the style bars. Looks too pimped IMHO |
Upper Sill clips in here
Update: I now would not recommend adding the extra leading rear wheel arch protection strips:
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 82 ![]() ![]() ![]() |
Going to tackle this next weekend; appreciate you adding the comment about not using the strips anymore as I was about to pull the trigger. |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 ![]() ![]() |
I'm about to remove the rust under the sills during spring and thought it could be great to purchase plastic fixings in case any break but also just to replace them all. Does any know from the blue print how many clips per side I would need to purchase? I have a hard time understanding which clips are the ones offered by Advanced Factors. Is DYC500080 HC1 or HC6 for example? Blue print = https://parts.jaguarlandroverclassic.com/dyc000091-clip.html |
